perspicacia
I just tested a Movie with ".webdl." in the filename and I see the webdl icon. Can you post the filename of the Movie you're having trouble with?
latts9923
Star Trek Renegades (2015).720p.webdl.AAC.mkv
perspicacia
Hmm...I just tried your filename as a test and it's displaying the webdl icon. I'm not sure why you see the webtv icon instead.
latts9923
Other files named the same way with ".WEB-DL." having same problem
latts9923
Solved - I think.
Manually checked Mod version against what was in your repo and needed updating (even though nothing in "Available Updates")
Have got webdl icon displayed now. Media Case still has webtv icon. Any chance there will be an option for weddl in future?
perspicacia
I don't think you'll get an Available Update notice with the Multi-Mod since I keep the same version number. If the webdl icon displays, then the webdl case should as well. What view are you using?
latts9923
Currently have it in PANEL view, but have tried all the other views that use media case (MULTIPLEX, GLASS LIST, COVERFLOW, WIDE, WALL, SHOWCASE, SETS, POSTER ZOOM) and the all have webtv case despite showing webdl icon in media bar, except both LIST 3D and both SHELF 3D which use the BLURAY case
perspicacia
Ah...yeah, I see the WEBTV icon on the case in the Panel view. Check the Right List view...it should be displaying the WEB-DL case. All the views you mentioned above use the same code to display the WEBTV icon...there is no code to display the WEB-DL icon. That will be a a fairly big code tweak. Let me work on it.
latts9923
(2024-01-15, 23:03)latts9923 Wrote: [ -> ]@perspicacia
Yes, that is exactly right
Thought that might be the case
Thanks for the assistance
perspicacia
I have the webdl videocodec and case working. It will be included in the next update.
Dumb question and apologize if answered... searching on this topic in forums is very hard for me.
What exactly does Multi-Mod mean? I like MQ8, and have upgraded to Omega, which I see is MQ9. Can I install MQ8-Multi-Mod on Omega?
js28194
I started calling it the "Multi-Mod" when I was adding mods to Aeon MQ 7. Multi-Mod just means that there are multiple modifications made to the skin. Right now MQ 8 is only available for Leia, Matrix and Nexus.
(2024-01-21, 21:23)latts9923 Wrote: [ -> ]@js28194
OK thank you for explanation. I hope there is MQ 8 for Omega. I really personally do not like MQ 9 in it's current state for Omega. I am so used to your MQ 8, completely configured. MQ 9 has menu's in the middle, when I hit down on main menu, it goes to quick edit, then hit down again to get true sub-menu, which pops in the middle of the screen. I am sure you have your reasons and thank you for your great work. I will stick to Nexus and MQ 8 for now as I still cannot get DV to play at all in Omega beta 2 quitevoid mods
