The current behaviour is;
You play content in a different frame rate to current display.
Content begins to play instantly (in wrong frame rate).
Then shield changes frame rate.
Then the content holds on a freeze frame wherever it left off (about 2 seconds into playback) for the duration of time set in setting menu (0-20 seconds).
Then payback resumes from where it left off.
Ie the switch happens after playback begins, not before.
I am having these problems with a movie in all my devices and I was about to open a thread...
Can wait to 18.6, hope its comes soon
(2020-02-14, 07:07)fritsch Wrote: [ -> ]http://mirrors.kodi.tv/nightlies/android...64-v8a.apk
Test the Leia nightly and report back. Properly set your delay. If it does not work come back with a Debug Log.
Without you guys verifying there will be a big whining party after 18.6 is out without another fix for months in Leia.
First of all, sorry if it's another problem different of the one of this thread.
http://paste.kodi.tv/bolovaxiju
Here is my log with that movie, installed the latest .apk still getting this frame low and audio desync, any help?
PD: Ofc the movie is working fine with VLC on my PC or using the google drive app.
Sorry, create your own thread. What this thread does not need at all - is some highjacking for another issue.
Please create your own issue report.
Ok log created
Playback of 23.98p 1080 file followed by 25i 576 file (played back @ 50p) then back to 23.98p 1080.
Each time, the frame rate switch happens after the file playback has already begun, causing freeze in vision & screen goes to black during switch.
Kodi is up scaling to UHD.
https://paste.kodi.tv/ipayosiyiv
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
Your issue is not related to the original problem. Your's is: You have 25 hz in your whitelist, when starting the 25i channel, it is detected as 25 hz and afterwards deinterlaced to 50. So it switches twice. Remove the 25 hz resolution from your whitelist.
(2020-02-23, 13:32)DarrenHill Wrote: [ -> ]The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
Can you tell me which these are please?
(2020-02-23, 14:05)fritsch Wrote: [ -> ]Your issue is not related to the original problem. Your's is: You have 25 hz in your whitelist, when starting the 25i channel, it is detected as 25 hz and afterwards deinterlaced to 50. So it switches twice. Remove the 25 hz resolution from your whitelist.
My set up is exactly as it used to be prior to version 18, and the switching always used to work fine.
At some point either at the end of version 17, or when it updated to 18 it broke.
I will try your suggestion now.
(2020-02-23, 19:56)MattJ2000 Wrote: [ -> ] (2020-02-23, 14:05)fritsch Wrote: [ -> ]Your issue is not related to the original problem. Your's is: You have 25 hz in your whitelist, when starting the 25i channel, it is detected as 25 hz and afterwards deinterlaced to 50. So it switches twice. Remove the 25 hz resolution from your whitelist.
I have removed 25hz from the whitelist. The behaviour is still the same I’m afraid.
(2020-02-23, 19:51)MattJ2000 Wrote: [ -> ]Can you tell me which these are please?
2020-02-23 10:35:53.966 T:25196 NOTICE: ADDON: plugin.program.supremebuildswizard v4.0.1 installed
2020-02-23 10:35:53.967 T:25196 NOTICE: ADDON: repository.supremebuilds v1.0.2 installed
(2020-02-23, 20:09)MattJ2000 Wrote: [ -> ] (2020-02-23, 19:56)MattJ2000 Wrote: [ -> ] (2020-02-23, 14:05)fritsch Wrote: [ -> ]Your issue is not related to the original problem. Your's is: You have 25 hz in your whitelist, when starting the 25i channel, it is detected as 25 hz and afterwards deinterlaced to 50. So it switches twice. Remove the 25 hz resolution from your whitelist.
Then bad for you. Time to file a bugreport with detailled
Debug Log on github.
Looking at your log once more:
Quote:2020-02-23 10:36:36.436 T:25175 NOTICE: VideoPlayer: OnLostDisplay received
2020-02-23 10:36:36.436 T:25402 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_PAUSE: 1
2020-02-23 10:36:37.068 T:25393 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
2020-02-23 10:36:37.068 T:25393 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_PAUSE: 1
2020-02-23 10:36:37.436 T:25196 DEBUG: Previous line repeats 1 times.
2020-02-23 10:36:37.436 T:25196 DEBUG: Flush - flushing renderer
2020-02-23 10:36:37.437 T:25175 DEBUG: CXBMCApp::onReceive - Got intent. Action: android.media.action.HDMI_AUDIO_PLUG
2020-02-23 10:36:37.437 T:25175 DEBUG: -- HDMI state: on
2020-02-23 10:36:37.437 T:25175 DEBUG: CWinSystemAndroid::SetHdmiState: state: 1
2020-02-23 10:36:39.295 T:25393 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
2020-02-23 10:36:41.179 T:25404 ERROR: Previous line repeats 1 times.
2020-02-23 10:36:41.180 T:25404 DEBUG: Thread Timer 25404 terminating
2020-02-23 10:36:41.193 T:25196 DEBUG: CWinSystemAndroid::SetHdmiState: state: 1
2020-02-23 10:36:41.194 T:25196 NOTICE: VideoPlayer: OnResetDisplay received2020-02-23 10:36:36.436 T:25175 NOTICE: VideoPlayer: OnLostDisplay received
Kodi waits properly for 5 seconds. But it finds that information only after your playback has long started. There is a problem with analyzing your .ts file - it comes up with 0 hz and 0 audio channels. After we played some amount, we find the real info and switch - here your timeout of 5 seconds is honored.
Try some mkv file, please.
