Full Version: Changes to the skinning engine for Kodi Matrix
Pages: 1 2 3 4
Below you'll find an up-to-date list of all changes made to the skinning engine since the release of Kodi Leia.
new infolabels
changed infolabels
deprecated infolabels
new infobools
changed infobools
removed infobools
new builtin actions
changed builtin actions
  • the xbmc. prefix is no longer supported (details)
  • PlayMedia() '1' param support for music (details)
new control type
new windows
removed windows
DialogAddonInfo.xml
DialogPVRInfo.xml
addon.xml
functional change
Please keep this thread clean. It should be an easy overview for skinners who are updating their skin for Kodi.
For discussions / feature requests / bug reports, please find (or create) the appropriate thread in the skin development forum.
2019-04-16 control type
a new control type has been added to Kodi: ranges
this new control can be used to mark certain parts of a progress control.
pull-request: https://github.com/xbmc/xbmc/pull/15767
commit: https://github.com/xbmc/xbmc/commit/cfba...3d031d2014
2019-04-16 new infolabels
- Player.CutList
- Player.Chapters
these infolabels can be used with the ranges control, as EDL and chapter markers
2019-04-16 pvr reminders
support for PVR reminders has been added to Kodi.
this introduces two new infobools:
- ListItem.HasReminder
returns True if the item has a reminder set (PVR)
- ListItem.HasReminderRule
returns True if the item was scheduled by a reminder timer rule (PVR)
and a new button in DialogPVRInfo.xml
- id="11" / label = 826
pull-request: https://github.com/xbmc/xbmc/pull/15467
commit: https://github.com/xbmc/xbmc/commit/e4d0...25f0644872
2019-04-24 new infobools
- ListItem.IsPlayable
returns True when the selected programme can be played (PVR)
- ListItem.HasArchive
returns True when the selected channel has a server-side back buffer (PVR)
pull-request: https://github.com/xbmc/xbmc/pull/15953
commit: https://github.com/xbmc/xbmc/commit/991f...699942ac2f
2019-05-21 new infolabel
- ListItem.FileNameNoExtension
will return the filename without it's extension
pull-request: https://github.com/xbmc/xbmc/pull/16152
commit: https://github.com/xbmc/xbmc/commit/fcfb...6706dd4f68
2019-05-24 removed window
- DialogAccessPoints.xml
this legacy / unused window has been removed from kodi.
pull-request: https://github.com/xbmc/xbmc/pull/16120
commit: https://github.com/xbmc/xbmc/commit/89cd...60343a590b
2019-07-03 new infobool
- PVR.IsPlayingActiveRecording
returns True when Kodi is currently playing a recording that is in progress.
pull-request: https://github.com/xbmc/xbmc/pull/16343
commit: https://github.com/xbmc/xbmc/commit/9dfe...539e70dd3a
2019-04-16 DialogPVRInfo.xml - find similar button
you can now also add the "Find similar" button (id="4" / label=19003) to the PVR recording info dialog (DialogPVRInfo.xml / PVRRecordingInfo).
pull-request: https://github.com/xbmc/xbmc/pull/15648
commit: https://github.com/xbmc/xbmc/commit/ab11...4a6324215f
2019-05-03 DialogVideoInfo.xml - support for movie sets
you can now add support for movie sets in DialogVideoInfo.xml
pull-request: https://github.com/xbmc/xbmc/pull/15315
commit: https://github.com/xbmc/xbmc/commit/ae89...ab6090e56f
2019-04-16 DialogAddonSettings.xml - addon settingslevel button
you can add a button (id="20") to DialogAddonSettings.xml
this will allow users to control the addon settingslevel.
pull-request: https://github.com/xbmc/xbmc/pull/15796
commit: https://github.com/xbmc/xbmc/commit/efe7...c732d6b1e0
2019-08-20 new infolabel
- ListItem.CurrentItem
will return the current index of the item in a container starting at 1.
pull-request: https://github.com/xbmc/xbmc/pull/15527
commit: https://github.com/xbmc/xbmc/commit/e48f...61b064584a
2019-08-20 new infobools
- Integer.IsEven
return True if the value of the infolabel is even
- Integer.IsOdd
return True if the value of the infolabel is odd
Example:
Integer.IsEven(ListItem.CurrentItem)
2019-07-09 DialogPVRGroupManager.xml
Thumbnail images are now automatically generated out of the logos contained in a PVR channel group (for home screen widgets etc.).
You can now add a button (id="35" / label=13315) to DialogPVRGroupManager.xml
This will regenerate the channel group thumbnails.
You can also add a ListItem.Icon for container id=13 to show the generated thumbnail image.
pull-request: https://github.com/xbmc/xbmc/pull/16360
commit: https://github.com/xbmc/xbmc/commit/3c75...8998655233
Pages: 1 2 3 4
