2019-04-30, 05:42
I have Always Sunny in two file locations. The first location got too full. Now the show is split between two file location sources. It shows up twice in the TV library view. Is this normal?
(2019-04-30, 05:48)Karellen Wrote: [ -> ]Hello @geronimo1958
No, it is not normal, but can happen. Some reasons it may happen...
1. The two tv show folders are not identically named
2. You have NFO files in both folders and they contain slightly different information
3. You have NFO file in one folder, but not in the other.
Any of those apply to you?
(2019-04-30, 06:23)Karellen Wrote: [ -> ]Ok. Can you...
1. Delete the two shows from your library and run a Clean Library (If you don't want to lose certain information, let me know)
2. Provide a Debug Log which captures you re-scraping the show into the library
3. Provide a screenshot for each folder so we can see the name and the contents.
(2019-04-30, 06:42)Karellen Wrote: [ -> ]If it is all fixed, then no need to create the Debug Log or the screenshots. It is too late to create it anyway, as it needed to be running while you performed the Update Library.
To create the Debug Log is only a few steps and the wiki page will guide you through it.
I'll mark this as solved. Enjoy!!
