2019-05-21, 12:55
2019-05-21, 12:55
2019-05-21, 15:54
When I point a home-tile to a specific source
Menu customisation using the "Skin Shortcuts" addon.
https://kodi.wiki/view/Add-on:Skin_Shortcuts
Supported Features Custom widget No
it may be the theme you can try estuary and create a node
2019-05-21, 19:02
Thanks for your reply!
If I change the skin, the home-menu buttons are totally different and changes does not apply for other skins.
I installed skin-shortcuts addon but the same (empty) screen appears anyways.
Maybe it is impossible to add 'sources' as targets for buttons?
