Full Version: Cannot select Audio Track / Audio Stream in Kodi 18.2 / 18.3rc on Android with MKV
I'm trying to get the option to switch the audio stream / track.
Setup:
I'm using android (s912 7.1.2 and Shield Tablet 7.0 / kodi 18.2 and 18.3RC) to play an mkv file with two audio tracks.
Both tracks are in English.
One is the audio for the file, the other is a dvd commentary.
On android, only the DVD commentary track plays.
I cannot switch it.
My troubleshooting:
Kodi on windows 10 both tracks show up.
The correct audio is default, I can switch to the commentary if I want.
Settings >System >Audio are the same in kodi on windows and android
I have tried switching up most of the audio settings, but as of now, they are the same as the working kodi system on windows
(FYI - I am streaming the file from google drive, but this shouldn't matter as it works on windows)
Update with a few questions:
Android phone - Android 9 - 18.2 - both audio tracks work...
Correct track playing first, I can switch to commentary if I want
So, is this a problem with Android 7?
or
Is it specific to 32bit (Shield tablet and s912 build) vs 64bit (phone)?
or ...
is this something else that is solvable? (settings / build)
Any contribution appreciated... also, if it works / doesn't can you post:
Android version: 6,7,8,9 etc
Android: 32 or 64bit version
Audio tracks work / don't work
Any help would be appreciated as I continue to have this problem.
I have uninstalled, cleared all, and reinstalled fresh.
Same problem.
Am I the only one with this playback issue on android?
bump
(2019-06-27, 16:15)User_1234 Wrote: [ -> ]bump
bump
(2019-12-14, 22:40)User_1234 Wrote: [ -> ]
bumpStill same problem 18.5 kodi on shield tablet
Nothing to bump here at all - post your Debug Log
