Full Version: Fixed list menu
The fixed list switch on mq8 is not working.
I only have three menus on the home screen, so with the fixed list switch set to on, they should not scroll.
I posted a similar post with regards to aeon mq7. Unfortunately the fix for mq7 does not work on Mq8 as the xml file includesMainMenu.xml does not exist. At least I cannot find it.
So any ideas? Any help would be appreciated.
Link to the previous fix:
https://forum.kodi.tv/showthread.php?tid=302014
