2019-06-25, 19:15
I did a apt dist-upgrade / reboot and reinstalled Kodi..... I had planed to restore my backup but ... at this point if all I have to fix is Zoneminder and reconfigure Kodi I'm happy. It was likely just some bad libs/depends. Thank god I didn't have to reinstall. Still have a little work to get pulseaudio-dynamic-range-compression working but that's really it!
I looked at https://forum.kodi.tv/showthread.php?tid=324365 seems to be sort of the same issue maybe ? VA-API not working ?
* followed guide for mesa https://unix.stackexchange.com/questions...n-debian-9 mesa 18.2.8-2~bpo9+1
* vlc renders perfectly with almost no CPU where as before it was like 50% CPU so I know GPU is working on some level
* xfce loads fine
* chrome://gpu https://rmccurdy.com/stuff/gpu.html
* plex transcodes just fine no CPU
* kodi logs https://pastebin.com/f1YHWjQt
* kodi runs fine over xfwd /ssh so must be video issues ?
* dmesg https://rmccurdy.com/stuff/dmesg.txt
* kodi 5:17.6-dmo1+deb9u3
* dpkg -l https://rmccurdy.com/stuff/dpkg.txt
cat ./os-release
PRETTY_NAME="Debian GNU/Linux 9 (stretch)"
NAME="Debian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
root@plex:/etc# uname -a
Linux plex 4.19.0-0.bpo.5-amd64 #1 SMP Debian 4.19.37-4~bpo9+1 (2019-06-19) x86_64 GNU/Linux
* Phoronix Test Suite v8.8.1
System Information
PROCESSOR: Intel Core i7-8700 @ 4.60GHz
Core Count: 6
Thread Count: 12
Extensions: SSE 4.2 + AVX2 + AVX + RDRAND + FSGSBASE
Cache Size: 12288 KB
Microcode: 0xb4
Scaling Driver: intel_pstate powersave
GRAPHICS: Intel UHD 630
Frequency: 1200MHz
Display Driver: modesetting 1.19.2
Screen: 1920x1080
MOTHERBOARD: ASRock H310M-HDV
BIOS Version: P4.10
Chipset: Intel Cannon Lake PCH
Audio: Realtek ALC887-VD
Network: Realtek RTL8111/8168/8411
MEMORY: 2 x 8192 MB DDR4-2667MHz CMK16GX4M2Z3466C16
DISK: 128GB SAMSUNG MZ7TE128 + 2 x 4001GB Western Digital WD4003FZEX-0
File-System: ext4
Mount Options: errors=remount-ro relatime rw
Disk Scheduler: MQ-DEADLINE
OPERATING SYSTEM: Debian 9.4
Kernel: 4.19.0-0.bpo.5-amd64 (x86_64)
Desktop: Xfce
Display Server: X Server 1.19.2
Compiler: GCC 4.9.2
+ Open64 PARSE ERROR: Argument:-dumpversion Couldn t find match for argumentBrief USAGE: opencc [--noflush <bool>] [-i <file>] [-o <file>] [-c <file>] [--] [--version] [-h]For complete USAGE and HELP type: opencc--help
Security: l1tf: Mitigation of PTE Inversion; VMX: conditional cache flushes SMT vulnerable
+ mds: Mitigation of Clear buffers; SMT vulnerable
+ meltdown: Mitigation of PTI
+ spec_store_bypass: Mitigation of SSB disabled via prctl and seccomp
+ spectre_v1: Mitigation of __user pointer sanitization
+ spectre_v2: Mitigation of Full generic retpoline IBPB: conditional IBRS_FW STIBP: conditional RSB filling
vainfo
libva info: VA-API version 0.39.4
libva info: va_getDriverName() returns -1
libva error: va_getDriverName() failed with unknown libva error,driver_name=(null)
vaInitialize failed with error code -1 (unknown libva error),exit
lspci -v -s 00:02.0
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 630 (Desktop) (prog-if 00 [VGA controller])
Subsystem: ASRock Incorporation Device 3e92
Flags: bus master, fast devsel, latency 0, IRQ 126
Memory at a0000000 (64-bit, non-prefetchable)
=16M Memory at 90000000 (64-bit, prefetchable)
=256M I/O ports at 4000
=64 [virtual] Expansion ROM at 000c0000 [disabled]
=128K Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [100] Process Address Space ID (PASID)
Capabilities: [200] Address Translation Service (ATS)
Capabilities: [300] Page Request Interface (PRI)
Kernel driver in use: i915
Kernel modules: i915
lshw -c video
*-display
description: VGA compatible controller
product: UHD Graphics 630 (Desktop)
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:126 memory:a0000000-a0ffffff memory:90000000-9fffffff ioport:4000(size=64) memory:c0000-dffff
cat /boot/grub/grub.cfg | grep i915.alpha_support=1
linux /boot/vmlinuz-4.19.0-0.bpo.5-amd64 root=UUID=717d53bc-3eb4-4a12-948f-b2a303a5877c ro quiet i915.alpha_support=1
linux /boot/vmlinuz-4.9.0-8-amd64 root=UUID=717d53bc-3eb4-4a12-948f-b2a303a5877c ro quiet i915.alpha_support=1
linux /boot/vmlinuz-4.9.0-4-amd64 root=UUID=717d53bc-3eb4-4a12-948f-b2a303a5877c ro quiet i915.alpha_support=1
* xfce loads fine
cat ./os-release
VERSION_ID="9"
ID=debian
System Information
Core Count: 6
Thread Count: 12
Microcode: 0xb4
Frequency: 1200MHz
Screen: 1920x1080
BIOS Version: P4.10
File-System: ext4
Desktop: Xfce
Compiler: GCC 4.9.2
vainfo
lspci -v -s 00:02.0
lshw -c video
*-display
physical id: 2
version: 00
width: 64 bits
clock: 33MHz
