Full Version: Raspberry PI / Kodi wont start after upgrading raspbian to buster version
Raspberry pi 2 b, raspbian buster - stable version
I have problem with starting Kodi on my raspberry PI. Before upgrading raspbian from stretch to buster kodi works great. After upgrading to buster kodi stops working.
below is crashlog from kodi
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
 Date: pon, 1 lip 2019, 16:46:18 CEST
 Kodi Options:
 Arch: armv7l
 Kernel: Linux 4.19.56-v7+ #1242 SMP Wed Jun 26 17:31:47 BST 2019
 Release: Raspbian GNU/Linux 10 (buster)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
############# END STACK TRACE ###############
################# LOG FILE ##################
16:45:47.666 T:1830958944  NOTICE: special://profile/ is mapped to: special://masterprofile/
16:45:47.666 T:1830958944  NOTICE: -----------------------------------------------------------------------
16:45:47.666 T:1830958944  NOTICE: Starting Kodi from Debian (17.6 Debian package version: 2:17.6+dfsg1-4+b1). Platform: Linux ARM 32-bit
16:45:47.666 T:1830958944  NOTICE: Using Release Kodi from Debian x32 build
16:45:47.667 T:1830958944  NOTICE: Kodi from Debian compiled from 2:17.6+dfsg1-4+b1 by GCC 8.2.0 for Linux ARM 32-bit version 4.18.20 (266772)
16:45:47.667 T:1830958944  NOTICE: Running on Raspbian GNU/Linux 10 (buster), kernel: Linux ARM 32-bit version 4.19.56-v7+
16:45:47.667 T:1830958944  NOTICE: FFmpeg version/source: 4.1.3-1+rpt1
16:45:47.667 T:1830958944  NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
16:45:47.667 T:1830958944  NOTICE: ARM Features: Neon disabled
16:45:47.667 T:1830958944  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
16:45:47.667 T:1830958944  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
16:45:47.667 T:1830958944  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
16:45:47.667 T:1830958944  NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
16:45:47.667 T:1830958944  NOTICE: special://envhome/ is mapped to: /home/pi
16:45:47.667 T:1830958944  NOTICE: special://home/ is mapped to: /home/pi/.kodi
16:45:47.667 T:1830958944  NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
16:45:47.667 T:1830958944  NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
16:45:47.668 T:1830958944  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin
16:45:47.668 T:1830958944  NOTICE: Local hostname: raspberrypi
16:45:47.668 T:1830958944  NOTICE: Log File is located: /home/pi/.kodi/temp//kodi.log
16:45:47.668 T:1830958944  NOTICE: -----------------------------------------------------------------------
16:45:47.690 T:1830958944   ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
16:45:47.884 T:1830958944  NOTICE: load settings...
16:45:47.968 T:1830958944   ERROR: PulseAudio: Failed to connect context
16:45:47.968 T:1830958944  NOTICE: PulseAudio might not be running. Context was not created.
16:45:48.037 T:1830958944  NOTICE: Found 1 Lists of Devices
16:45:48.037 T:1830958944  NOTICE: Enumerated ALSA devices:
16:45:48.037 T:1830958944  NOTICE:     Device 1
16:45:48.038 T:1830958944  NOTICE:         m_deviceName      : @
16:45:48.038 T:1830958944  NOTICE:         m_displayName     : Default (bcm2835 ALSA bcm2835 ALSA)
16:45:48.038 T:1830958944  NOTICE:         m_displayNameExtra:
16:45:48.038 T:1830958944  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
16:45:48.038 T:1830958944  NOTICE:         m_channels        : FL,FR
16:45:48.039 T:1830958944  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
16:45:48.039 T:1830958944  NOTICE:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
16:45:48.039 T:1830958944  NOTICE:         m_streamTypes     : No passthrough capabilities
16:45:48.057 T:1830958944  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
16:45:48.058 T:1830958944  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
16:45:48.058 T:1830958944  NOTICE: Default Video Player: VideoPlayer
16:45:48.058 T:1830958944  NOTICE: Default Audio Player: paplayer
16:45:48.058 T:1830958944  NOTICE: Disabled debug logging due to GUI setting. Level 0.
16:45:48.058 T:1830958944  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
16:45:48.059 T:1830958944  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
16:45:48.060 T:1830958944  NOTICE: Loaded playercorefactory configuration
16:45:48.060 T:1830958944  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
16:45:48.060 T:1830958944  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
16:45:48.095 T:1830958944  NOTICE: Running database version Addons27
16:45:48.212 T:1830958944  NOTICE: ADDONS: Using repository repository.xbmc.org
16:45:48.319 T:1830958944   ERROR: X11 Error: No Display found
16:45:48.319 T:1830958944   FATAL: CApplication::Create: Unable to init windowing system
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
Anyone have problem like that?
It's also readable on the Raspbian website(s): Kodi for Debian is currently v17.6 only.
FYI, this version is not packaged by Team Kodi.
You'll have to be patient with Raspbian, or try the newest RPi4 image from Milhouse.
(2019-07-01, 17:35)Klojum Wrote: [ -> ]It's also readable on the Raspbian website(s): Kodi for Debian is currently v17.6 only.
thanks for reply. So i know that is 17.6 on raspbian so on Buster it wont work? Maybe its related only to kernel version and i can roll to previous version?
(2019-07-01, 17:46)cosmita Wrote: [ -> ]Maybe its related only to kernel version and i can roll to previous version?
Buster is a new Raspbian release, which is merely days old. It has plenty of optimizations to do.
For a RPi-2b, I'd recommend LibreELEC if you only need Kodi.
Otherwise, use the previous Raspbian release+Kodi.
OK, TY i have to use Raspbian Stretch then and wait Smile
(2019-07-01, 22:59)cosmita Wrote: [ -> ]OK, TY i have to use Raspbian Stretch then and wait Smile
How its possible Raspbian Stretch have Kodi Leia 18.2 but Raspbian Buster old version 17.6 Huh strange Smile
(2019-07-02, 19:01)cosmita Wrote: [ -> ]
This question should be directed to RPF/RPT engineers on https://www.raspberrypi.org/forums/
(2019-07-02, 19:01)cosmita Wrote: [ -> ]How its possible Raspbian Stretch have Kodi Leia 18.2 but Raspbian Buster old version 17.6 Huh strange Smile
The buster version is the standard debian kodi (not built for Pi, so no hw acceleration).
Stretch has a custom version, which hasn't been updated for buster yet
(and it's complicated with Pi4 needing a different build).
It will come, but for now stick with stretch if you need kodi + raspbian.
(2019-07-03, 00:36)popcornmix Wrote: [ -> ]
Ty, i'll wait Smile. Maybe will buy another Pi > Pi4 to make media center Smile and leave Pi2 to do only house automation Smile
