I had no problem with krypton and Leia 18.1 but my picture became black and white since Leia 18.2 and same with Leia 18.3. running on windows 10. Any help welcome . Thanks in advance
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
(2019-07-03, 08:45)Fatboychris Wrote: [ -> ]but my picture became black and white since Leia 18.2
I'd like to see a screenshot of your monitor screen, with Kodi in windowed mode (not maximized) showing the rest in color. Not photoshopped.
(2019-07-03, 09:27)Klojum Wrote: [ -> ] (2019-07-03, 08:45)Fatboychris Wrote: [ -> ]but my picture became black and white since Leia 18.2
Here is a picture of what i deal with
https://ibb.co/9YbSX6Y
Problem solved . I went into the video settings and chosen stereoscpic 3D and switched to over/ under and the color came back. I have to do this for ever addon for a reason that I dont know.....
thanks everyone
