Version 2.9.3 released.
I believe this version will make everyone happy.
For a quick changelog read in the first page here I'll explain a little better the changes.
So the user _DMU_ supplied us with the source code and a compiled exe that was able to toggle Windows HDR ON and OFF.
I've tried to add the code to Kodi itself to merge and use it automatically just like Nvidia and AMD but the code would crash Kodi not matter what I tried.
The solution for this is to use the pre compiled exe file so if that would crash it would already have changed the Windows HDR state from ON to OFF or vice versa.
I've tried to create my own key combination but this did not work, so I replaced the screenshot feature that works during video playback and in the GUI Menus to toggle HDR on and OFF.
I've set this to CTRL+H press once to enable HDR and press again while it is on to disable it.
You can change the key combination for anything you like in the file:
Program Files\Kodi\System\keymaps\keyboard.xml
Changing the line:
<h mod="ctrl">Screenshot</h>
Since Kodi while building the installer will not add .exe files you will need to get it here:
https://github.com/fandangos/xbmc/blob/m...Config.exe
And place in your installation folder that is normally located here:
C:\Program Files\Kodi
Without this .exe file ctrl+h will do nothing.
This is
ONLY needed for Intel iGPU users since Intel doesn't have a public API that we can use and for problematic Ryzens that refuse to put the TV into BT.2020 mode.
All other AMD and Nvidia users can use this latest version normally.
I have removed a bunch of unnneded past stuff from RendererBase.
All the changes are available on github for anyone to check the source code.
Including the source for DisplayConfig.exe.
Hope this fix everything for everyone
