2019-11-08, 13:39
(2019-11-08, 12:28)m1dy Wrote: [ -> ](2019-11-07, 16:30)fandangos Wrote: [ -> ]@fandangos Please try to reproduce this bug again.(2019-11-06, 17:05)m1dy Wrote: [ -> ]OK I think I found a bug.
In fact the Plex addons don't have anything to do with what I described.
If you change subtitles for a movie and try to play that movie again you get blownout whites like I described.
Could reproduce it on a fresh install with a local hdr file.
Maybe it has something to do with kodi saving settings for the movie if you change something?
Before I changed subtitles:
After changing subtitles and stopped and played movie again:
Are you on AMD?
I can't reproduce this on Nvidia here and I can't test with AMD hardware at the moment.
Just tested it with another pc (Laptop with gtx1660ti). Exactly the same problem as my desktop pc with gtx960.
A movie works as long you didn't change any settings while playing it. If you change anything (audiotrack, subtitles, upscale method, etc...) it will be too bright the next times you play it. If you delete the video database (MyVideos116.db) that (besides other things) saves these changes the movie will work again with correct color. I checked multiple different movies and it was all the same.
For both PCs I did a fresh install and tested multiple movies that were on my hdd.
Couldn't test another tv as I only have one HDR tv. It's a Sony X9005F. But that shouldn't matter as it can't be the TV.
Not sure what is going on with your setup.
Started the video, changed subtitle, stopped and resumed.
Everything is fine.
