Full Version: youtube plugin shows low resolution video only (360p)
I've recently installed Kodi Leia (official) on xbox one along with the youtube add-on.
I'm stumped at getting high resolution video.
I've followed the usual advice (configure adaptative/rmtp video), but it seems the
problem lies elsewhere. In the youtube add-on, it says it needs mdash support to play
hi-res video, and that in turns requires an httpserver on the box.
I looked at the server parameters. No matter what I do, in IP check,
it says "HTTP server not running".
I assumed it might be because it tries to reach out from the outside world to contact the
server, but enabling upnp doesn't change anything.
Nor does opening a nat rule to the http server in my outside router.
So several questions:
1/ did I miss something obvious
2/ is there something missing from the xbox one port that means there's no http server?
3/ am I missing a dependency on some httpserver add-on ? and in which case, where can I get it ?
A quick search on the "official" xbox one repository shows nothing.
Thread moved to the XBOX section, as I think it would be better answered there.
Offhand I don't think the UWP version has or can use InputStream Adaptive, but I'm not 100% certain of that (and I don't own one to check).
(2019-09-17, 14:49)DarrenHill Wrote: [ -> ]Thread moved to the XBOX section, as I think it would be better answered there.
I'm quite willing to experiment to obtain more information, as long as one points me in the right direction.
The Xbox environment is somewhat hostile, I probably need to be pointed to the right add-on before I can provide proper logging.
(I have a full-featured Unix installation on the other side, my first reaction when installing kodi was "cool, something that understands nfs natively")
The inputstream adaptive it was just removed entirely on 18.5 update on xbox so some additional addons are not working now. Was working previously however on 18.4 for me not sure if may have been disabled for you or not in services. There must be a way to edit the working 2.4.2 inputstream adaptive which works on windows 18.5, restore a backup, or push the proper linux package util commands to it but kodi bit short on xbox devs atm
