I've got a hdd connected to kodi on the fire stick but I can't write to it. I can through total commander. How do I fix it to write with the file manager?
Which disk format does the HDD have?
(2019-11-02, 20:25)Klojum Wrote: [ -> ]Which disk format does the HDD have?
How do I check?
Plug it into a Windows (or Linux) machine, you should be able to find the disk's properties.
I got no idea what Total Commander can do in Android win that respect with HDDs.
(2019-11-02, 23:45)Klojum Wrote: [ -> ]Plug it into a Windows (or Linux) machine, you should be able to find the disk's properties.
I'm pretty sure that it's Fat32 since that's all that the firetv supports
