2019-11-16, 20:21
Reading the wiki it says I have to install Kodi every 7 days? Is there no work around for that? I wanted a Apple TV 4 as media unit but having to install Kodi every week won’t do it for me.
(2019-11-17, 06:41)noggin Wrote: [ -> ]Or you can use MrMC (which is in the App Store) - which is a fork of Kodi with all the functionality that breaches Apple's App Store Ts and Cs removed. (Mainly add-on support). PVR support is included for the main PVR platforms in MrMC.
(2019-11-17, 10:09)Exstaz Wrote: [ -> ](2019-11-17, 06:41)noggin Wrote: [ -> ]Or you can use MrMC (which is in the App Store) - which is a fork of Kodi with all the functionality that breaches Apple's App Store Ts and Cs removed. (Mainly add-on support). PVR support is included for the main PVR platforms in MrMC.
All options sounds like either to expensive or it might get disabled any day.
A Nvidia shield tv seems to do the job and no worries about it getting banned.
(2019-11-17, 12:35)wrxtasy Wrote: [ -> ](2019-11-17, 10:09)Exstaz Wrote: [ -> ](2019-11-17, 06:41)noggin Wrote: [ -> ]Or you can use MrMC (which is in the App Store) - which is a fork of Kodi with all the functionality that breaches Apple's App Store Ts and Cs removed. (Mainly add-on support). PVR support is included for the main PVR platforms in MrMC.
MrMC will not get banned, 100% certain of that. Talk of banning is just FUD.
It’s a legit tvOS App that has met Apple’s stringent App Store checks to even be available in the first place.
(2019-11-17, 12:47)Exstaz Wrote: [ -> ](2019-11-17, 12:35)wrxtasy Wrote: [ -> ](2019-11-17, 10:09)Exstaz Wrote: [ -> ]All options sounds like either to expensive or it might get disabled any day.
Ok so that is doing just the same thing as Kodi? Will it passthrough dts-hd to?
(2019-11-17, 15:58)wrxtasy Wrote: [ -> ]The only thing the ATV 4K cannot basically do is install Kodi from the tvOS App Store and do lossless Bluray Rip Atmos / DTS:X audio passthrough. You lose the height component of that type of audio on the ATV 4K.
However All audio like 5.1 / 7.1 AC3, DTS, DD+ (with lossy Atmos), Dolby TrueHD and DTS-HD MA is lossless decoded into 24bit 48kHz LPCM.
For no loss in audio quality
All HD audio capable AVR’s can handle 7.1 LPCM audio input.
It does not really matter if an AVR does the audio decoding or the ATV 4K. Audio output will be bitwise identical, using standard audio decode algorithms.
I cannot tell the difference aurally between my Yamaha AVR decoding Audio to LPCM vs the Apple TV 4K doing it. Sounds the same.
There is a lot of Apple TV 4K / MrMC info in the following review: https://forum.kodi.tv/showthread.php?tid=335219
