Thanks for answering on Youtube. Once I add the widget with the random path built I see this icon. When I click on it it just spins like it is trying but never ends and I have to do a hard reset. Thank you!
Quote:2020-04-02 17:33:56.653 T:123145308471296 NOTICE: plugin.program.autowidget: [ action: random ] [ group: movies-1585811537.14 ] [ mode: path ] [ id: 78d84305-0b3b-4b6a-b312-fd7078add61e ] 2020-04-02 17:33:59.271 T:123145308471296 NOTICE: plugin.program.autowidget: [ mode: force ] 2020-04-02 17:33:59.441 T:123145327329280 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value 2020-04-02 17:34:22.425 T:123145314910208 WARNING: DARWINOSX: underflow (0 vs 4096 bytes)
(2020-04-03, 05:19)derrgoo123 Wrote: [ -> ]Thanks for answering on Youtube. Once I add the widget with the random path built I see this icon. When I click on it it just spins like it is trying but never ends and I have to do a hard reset. Thank you!
Quote:2020-04-02 17:33:56.653 T:123145308471296 NOTICE: plugin.program.autowidget: [ action: random ][ group: movies-1585811537.14 ][ mode: path ][ id: 78d84305-0b3b-4b6a-b312-fd7078add61e ] 2020-04-02 17:33:59.271 T:123145308471296 NOTICE: plugin.program.autowidget: [ mode: force ] 2020-04-02 17:33:59.441 T:123145327329280 WARNING: [xbmcswift2] No converter provided, unicode should be used, but returning str value 2020-04-02 17:34:22.425 T:123145314910208 WARNING: DARWINOSX: underflow (0 vs 4096 bytes)
I'm sorry, but I would really need to see your whole log. I would recommend using something like the Kodi Log Uploader add-on to upload your log file and attach a link here.
(2020-04-03, 05:33)drinfernoo Wrote: [ -> ] (2020-04-03, 05:19)derrgoo123 Wrote: [ -> ]Thanks for answering on Youtube. Once I add the widget with the random path built I see this icon. When I click on it it just spins like it is trying but never ends and I have to do a hard reset. Thank you!
See if you can download from here..
https://1drv.ms/u/s!Avq7cvK-WeDhgfcwj7Ag...Q?e=5ywvLe
(2020-04-03, 05:51)derrgoo123 Wrote: [ -> ] (2020-04-03, 05:33)drinfernoo Wrote: [ -> ] (2020-04-03, 05:19)derrgoo123 Wrote: [ -> ]Thanks for answering on Youtube. Once I add the widget with the random path built I see this icon. When I click on it it just spins like it is trying but never ends and I have to do a hard reset. Thank you!
See if you can download from here.. https://1drv.ms/u/s!Avq7cvK-WeDhgfcwj7Ag...Q?e=5ywvLe
While AutoWidget shouldn't have any problem working with add-on content, there is simply too much going on for me to try and diagnose your system. Consider trying it out in a clean "build" instead to see if it works for you.
derrgoo123
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
(2020-04-03, 07:49)drinfernoo Wrote: [ -> ] (2020-04-03, 05:51)derrgoo123 Wrote: [ -> ] (2020-04-03, 05:33)drinfernoo Wrote: [ -> ]I'm sorry, but I would really need to see your whole log. I would recommend using something like the Kodi Log Uploader add-on to upload your log file and attach a link here.
Noted. Please see new log.
https://1drv.ms/u/s!Avq7cvK-WeDhgfcvxFWk...Q?e=RKvhSV
Ok so setup all the widgets got the all in place but it doesnt change the content it just stays on the same content
for instance i have a widget which is called catchup and is pointing to several paths from iplayer catchup tv and itv but it picked 1 and it doesnt change it
is this the correct behaviour?
This acts correctly in arctic horizon, i think it has something to do with adding the widget from favourites
The problem facing embruary is that because the addon is a program addon you cant navigate to it from the widgets section is there a way to change the addon type to a video addon?
(2020-04-03, 08:54)derrgoo123 Wrote: [ -> ] (2020-04-03, 07:49)drinfernoo Wrote: [ -> ] (2020-04-03, 05:51)derrgoo123 Wrote: [ -> ]See if you can download from here.. https://1drv.ms/u/s!Avq7cvK-WeDhgfcwj7Ag...Q?e=5ywvLe
Noted. Please see new log. https://1drv.ms/u/s!Avq7cvK-WeDhgfcvxFWk...Q?e=RKvhSV
This log doesn't even appear to have AutoWidget installed, or a skin with widgets, and there are no errors.
(2020-04-03, 09:49)popeye2468 Wrote: [ -> ]Ok so setup all the widgets got the all in place but it doesnt change the content it just stays on the same content
I need to know what skin you're on, and hopefully a few examples of paths you're trying to use.
One more time: If you have issues, I need to know what skin you're on at the very least.
(2020-04-03, 10:41)popeye2468 Wrote: [ -> ]This acts correctly in arctic horizon, i think it has something to do with adding the widget from favourites
What do you mean? The only skin I've run into that does it this way is Xonfluence.
Quote:The problem facing embruary is that because the addon is a program addon you cant navigate to it from the widgets section is there a way to change the addon type to a video addon?
I'll do some testing in Embruary. If it has configurable widgets, there should be no reason why it won't work. AutoWidget isn't a video add-on, because it doesn't
provide video, and can make widgets from anything, including other addons besides video. That's why it's a program add-on.
(2020-04-03, 16:19)drinfernoo Wrote: [ -> ] (2020-04-03, 10:41)popeye2468 Wrote: [ -> ]This acts correctly in arctic horizon, i think it has something to do with adding the widget from favourites
I'll do some testing in Embruary. If it has configurable widgets, there should be no reason why it won't work. AutoWidget isn't a video add-on, because it doesn't provide video, and can make widgets from anything, including other addons besides video. That's why it's a program add-on.
This is on a fresh install after adding the widget auto widget just runs an error from then on and does not change the widget. Heres the full log
https://pastebin.com/zazcWmkN
(2020-04-03, 16:16)drinfernoo Wrote: [ -> ] (2020-04-03, 09:49)popeye2468 Wrote: [ -> ]Ok so setup all the widgets got the all in place but it doesnt change the content it just stays on the same content
Ok so on embruary skin and using either tmdbhelper from jurialmunkey or embruary helper from the skin itself
if it helps version 1.3.4 does not error but it doesnt switch up the widgets
Using Arctic Horizon I edited the Plot on a row of shortcuts & expected it to appear under the Title but it shows 'No information available'. Is this expected behaviour?
