2020-07-24, 11:57
2020-07-24, 19:57
(2020-07-24, 11:57)rascas Wrote: [ -> ]Update your system and try again. You should have 5.4.x kernel now.
Hmmm good suggestion, but I'm now runningĀ 5.4.51-v7l+ and the problem persistsĀ
2020-07-24, 20:29
Do you have a 5.1 sound system or does it happen only with 5.1 audio? If not, probably it is not the same problem.
Anyway reproduce your problem and post a Kodi debug log: https://kodi.wiki/view/Log_file
2020-07-26, 04:57
(2020-07-24, 20:29)rascas Wrote: [ -> ]Do you have a 5.1 sound system or does it happen only with 5.1 audio? If not, probably it is not the same problem.
Yes, I have a 5.1 system...I've only noticed it on 5.1 audio, but I can't confidently say it doesn't happen on others. Here's a log of it happening a few times http://paste.ubuntu.com/p/TFyDwbjgQp/ ...there's a really good example at the resume at 2020-07-25 20:30:18.261...didn't get audio for ~8 seconds after unpause
2020-07-27, 10:49
(2020-07-26, 04:57)redec Wrote: [ -> ](2020-07-24, 20:29)rascas Wrote: [ -> ]Do you have a 5.1 sound system or does it happen only with 5.1 audio? If not, probably it is not the same problem.
Do you have "Keep audio device alive" and "Send low volume noise" enabled in System Settings > Audio?
I know that when pausing without these options my AVR switches to stereo mode and it takes a few seconds to go back to multichannel on resume.
I doubt this is it for you since you seem to only pause for 10s in your log though.
2020-07-27, 17:47
(2020-07-27, 10:49)Axionkt Wrote: [ -> ]I have tried it both ways...it has no effect on my issue.(2020-07-26, 04:57)redec Wrote: [ -> ](2020-07-24, 20:29)rascas Wrote: [ -> ]Do you have a 5.1 sound system or does it happen only with 5.1 audio? If not, probably it is not the same problem.
At any rate I think I'm hijacking this thread for a different issue, so I've started a new thread for my issue here
2020-11-24, 12:33
(2020-06-22, 22:04)popcornmix Wrote: [ -> ]I have a test firmware here that may help with the mixed channel issue.Is this still applicable and is it applicable to Pi 400 or has it trickled down to a Raspbian image installed a week ago?
If you are affected can you test it? Use the files from the zip file to replace start.elf/fixup.dat on the boot partition of sdcard.
Let me know if it helps.
Note: On Libreelec you need to rename start4.elf to start.elf and fixup4.dat to fixup.dat (i.e. replace existing files).
2020-11-24, 13:01
(2020-11-24, 12:33)supsup Wrote: [ -> ]Is this still applicable and is it applicable to Pi 400 or has it trickled down to a Raspbian image installed a week ago?
Should be present. (needs "vcgencmd version" to report Jun 26 2020 or later).
2020-11-24, 13:47
is there a list of non working rpi4 stuff for le10?
is it reasonable for LE to follow kodi release schedule now that things like h264 video accleration lack skip/jump for example?
Thanks for everyones efforts
2020-11-24, 14:09
(2020-11-24, 13:01)popcornmix Wrote: [ -> ]Indeed, my version is Oct 22 2020.(2020-11-24, 12:33)supsup Wrote: [ -> ]Is this still applicable and is it applicable to Pi 400 or has it trickled down to a Raspbian image installed a week ago?
