2008-08-12, 14:31
2008-08-12, 14:58
When you navigate to a dir that has a *.rar file in it, that is protected by a password, XBMC Atlantis crashes.
2008-08-12, 15:00
Please open a trac ticket if this is reproduceable.
edit: and add a small sample file to it.
2008-08-12, 15:29
Done, it's actually the encrypted filenames (not the password protection) XBMC can't handle.
For others wondering how to submit a trac ticket, take a close look at WiSo's signature.
2008-08-12, 16:29
Wiso,
is this normal the API function PostMessage KEYDOWN KEYUP dont work with the version ATLANTIS ?
2008-08-12, 16:45
I don't know why this is happening (and I don't believe a log would help either) but this build is having trouble registering button presses from my remote which is working in conjunction with EventGhost.
I've checked the log in EG and every button press is registering fine with it but they're just not working properly in XBMC - sometimes I have to press a button over 6 times for XBMC to actually do anything.
2008-08-12, 18:03
Still having problems with the DVD playback in this build, when ever a DVD has a language preselection menu, before it starts up the DVD-menu, XBMC gets stuck in there. Also on some DVDs I couldn't get the main feature to start, xbmc would lock up in the DVD-menu when I tried.
Remarkably all problems were gone, once I riped the content of those DVDs to my harddrive, so it seems it has something to do with the DVD-drive integration.
2008-08-12, 18:35
Sorry to sound like such a noob, but is "XBMC for Windows Atlantis - alpha3" just another build for windows or a new operating system called atlantis
2008-08-12, 18:52
live2give Wrote:Sorry to sound like such a noob, but is "XBMC for Windows Atlantis - alpha3" just another build for windows or a new operating system called atlantis
It's a new build for xbmc, not the name of a new OS, MS has 3 other OS'es to finish first
Atlantis is the codename for the upcoming offical xbmc release, read about it here: http://forum.xbmc.org/showthread.php?tid=35795
2008-08-12, 18:58
Its a build for windows. You can read about the Altantis build here http://forum.xbmc.org/showthread.php?tid=35795
on preview... Jereon beat me to it.
Maybe a more appropriate name would be 'XBMC Atlantis for Windows' ?
2008-08-12, 19:30
Hitcher Wrote:I don't know why this is happening (and I don't believe a log would help either) but this build is having trouble registering button presses from my remote which is working in conjunction with EventGhost.
my ATI X10 remote has stopped working with this build also
2008-08-12, 19:41
and on my other machine the MCE remote has stoped working with xbmc. (through IR Server Suite)
2008-08-12, 20:25
If something doesn't work then please post a trac report about it.
It's quite possibly due to the changed location for IRSSmap.xml (assuming you have altered it?)
2008-08-12, 20:32
jmarshall Wrote:If something doesn't work then please post a trac report about it.
That's the wierd thing though EventGhost just converts my remote IR inputs to keyboard presses but using the keyboard directly is fine.
2008-08-12, 20:35
I installed the Atlantis build into separate folder but still using the -p switch and my MCE remote working fine with IR Server Suite
