Periodically my saved channel groups disappear and I'm left with just the standard channel groups. Normally I just recreate the groups but I'm wondering, is there is a way to prevent this?
Is this a Kodi problem or a Tvheadend problem?
Can they be backed up?
This most recently happened on my CoreELEC box but I've also had it happen on my Shield TV
(2020-11-02, 02:26)RKCRLR Wrote: [ -> ]Periodically my saved channel groups disappear and I'm left with just the standard channel groups. Normally I just recreate the groups but I'm wondering, is there is a way to prevent this?
How do you create the groups? With the tvheadend web UI or with Kodis channel group manager?
(2020-11-02, 09:21)ksooo Wrote: [ -> ] (2020-11-02, 02:26)RKCRLR Wrote: [ -> ]Periodically my saved channel groups disappear and I'm left with just the standard channel groups. Normally I just recreate the groups but I'm wondering, is there is a way to prevent this?
Kodi's channel group manager.
Does this happen after you 'clear data' in settings-pvr livetv-general ?
Manually created groups in kodi will be gone after doing this. If the backend provides the groups they will be reloaded from it in kodi.
Just tried with a backend with, and one without providing channels groups. My manual groups are gone.
(2020-11-03, 01:50)Atreyu Wrote: [ -> ]Does this happen after you 'clear data' in settings-pvr livetv-general ?
I don't remember doing a "clear data" the last time it happened. However, the CoreELEC box had locked up and I had to do a manual power cycle.
(2020-11-03, 02:26)RKCRLR Wrote: [ -> ] (2020-11-03, 01:50)Atreyu Wrote: [ -> ]Does this happen after you 'clear data' in settings-pvr livetv-general ?
Deactivate sync groups with backend in Kodi PVR settings. Look at the help text for explanation why this solves your problem.
(2020-11-03, 09:23)ksooo Wrote: [ -> ] (2020-11-03, 02:26)RKCRLR Wrote: [ -> ] (2020-11-03, 01:50)Atreyu Wrote: [ -> ]Does this happen after you 'clear data' in settings-pvr livetv-general ?
Thanks, I'll give that a try.
(2020-11-08, 09:38)ksooo Wrote: [ -> ] (2020-11-03, 23:12)RKCRLR Wrote: [ -> ] (2020-11-03, 09:23)ksooo Wrote: [ -> ]Deactivate sync groups with backend in Kodi PVR settings. Look at the help text for explanation why this solves your problem.
Did it work?
I could go months without having a problem so it's too early to tell for sure. But since syncing channels to backend was enabled it seems this was likely the problem.
