2020-11-24, 02:48
I struggled with Locast and worked on it for a couple of days so I decided to install several and try my luck.
Fox News - Installed without a hitch and seems to work ok.
Locast - Installed with no problems, but when you attempt to launch a message "Locast error, check the log for more information".
MeTV - Installed with no problems, seems to work ok.
retro tv - Installed with no problems, does not seem to launch correctly, all menu items are empty, app is not listed on the upper left hand side on the menu.
Smithsonian Channel - Installed with no problems, but when you attempt to launch a message "Smithsonian Channel error, check the log for more information.
TV Land - Installed with no problems, upon launch three menu items appear, "Latest Episodes, Browse Shows, Browse YouTube" clicking on the first two triggers an error "TV Land error, check the log for more information". The Browse YouTube option seems to work.
Xumo - Installed with no problems, seems to work, seems like a worthy add-on.
YouTube - Installed with no problems, after figuring out how to apply the API information it seems to work great.
This is on a fresh install of Kodi, also a fresh install of Windows 10 Pro, can this be something wrong with my system or are some of these add-ons not so good / stable. It seems difficult to install them incorrectly the interface is simple to use. Anybody else having the same problems?
