Full Version: How to Play Songs in Fullscreen mode?
I am new to this skin and have been trying to set this up with no luck.  How do I set the default to play songs in fullscreen mode (music visualisation screen)?  Many thanks.
(2020-11-26, 07:04)RobinTW Wrote: [ -> ]trying to set this up with no luck
Luck shouldn't be part of the equation. In settings>interface>startup you can chose startup window 'music'. Check this add-on https://forum.kodi.tv/showthread.php?tid=203290 and here
(2020-11-26, 22:13)PatK Wrote: [ -> ]
This only takes it to "Music" at startup.  I want to play songs in fullscreen mode automatically or at least by pressing a button.  I am using LibreELEC and TV remote with CEC as the control.  The control is very limited.
Did the add-on work?
Description:
This service simply executes party mode or playlist on Kodi startup or on screensaver.
(2020-11-27, 18:56)PatK Wrote: [ -> ]Did the add-on work?
Description:
Never mind.  I have switched to other skins that support the function.  Thanks anyway.
