Full Version: Feedback - No Dolby Vision, resuming video not working
Hi folks,
First off, congratulations on what you're doing regarding Kodi, this is the greatest tool ever and I thank you for supporting it and making it available to folks like me.
I have just installed KODI 19 Beta 1, in the hope that Dolby Vision would be supported. It has not worked out yet.
For a bit of background, I am using an MKV file of the latest copy of The Lord Of The Rings: The Fellowship Of The Ring in 4K DV. The MKV image was make thanks to MakeMKV using the official Bluray. I think it's important to note that I have also tried to use the M2TS file directly from the bluray, but it would not play on KODI 18.9, so I moved to the MKV file instead, still no luck, then tried the MKV on KODI 19. Lastly, using the Bluray player straight to the TV, DV works fine. I have also tried The Matrix, to no avail either.
I am using an Nvidia Shield Pro 2020, with a Sony X900f, all fully compatible Dolby Vision (works with the Bluray player, and Netflix).
Also, resuming a video does not work. The sound does not play and the image does not show.
DV only works in an mp4 or mov container currently.
Kodi + Shield + Dolby Vision
(2020-12-06, 11:57)Hitcher Wrote: [ -> ]DV only works in an mp4 or mov container currently.
Hi, Thanks for the answer.
I have tried an MP4 version of my bluray using DVDFab, with the support option for Dolby Vision checked, to no avail on KODI 19 Beta 1. I have not tried .mov.
I have tried the .mkv version from MakeMKV with Plex, and Dolby Vision does work with no issue.
Let me know if I can do any other testing that could help, I'd be glad to give a hand.
It needs to be single layer.
(2020-12-13, 10:55)Hitcher Wrote: [ -> ]It needs to be single layer.
How does that affect the MP4? Mind elaborating a bit?
So Kodi is currently capable of playing SL DV remuxes in these containers? Hopefully mkv will be on the way soon!
Edit: Thanks for that link, now i'm up to speed on the Kodi, DV with MKV, ffmpeg situation. Appreciate the info!
