Quote:- Under Videos->Add-Ons
- Select "Missing Movie Scanner"
- Use auto scan to scan you Movies or TV source paths
Hi I have followed the above instructions and there is no "Missing Movie Scanner" button and neither is there a 'manually add' film button.
Obi-Wan-420
This add-on is broken and has been for a number of years.
What are you trying to do?
(2021-01-05, 12:05)Karellen Wrote: [ -> ]@Obi-Wan-420
Add missing videos to Kodi's library. Without much luck
It's strange as if I scan it'll sometimes pick up X film but if I scan again it misses X film... I have double checked the format & names etc
(2021-01-05, 12:15)Obi-Wan-420 Wrote: [ -> ]Add missing videos to Kodi's library. Without much luck
Please provide a
Debug Log which captures you trying to scrape the movie and I should be able to see what the problem is.
If you want to check which movie did not scrape, use the
Event Log (wiki)
I will split your posts and move them to the correct forum.
