(2021-01-21, 13:44)jjd-uk Wrote: [ -> ]Don't know if you maybe pointed to wrong file as I don't why you think that has anything to do with media flags, that's simply a list of strings to strip off the filename before it's fed to the scraper for lookup on TMDB/IMDB or whatever to make it easier to identify.
For using
media stubs it seems to be the only way to set flags for a movie by the file name, as described in
Naming video files / Movies – Media Tags / Flags. You get no description how to name the files in detail, e.g. which text stands for a specific flag.
If you can use e.g. "4K" in the file name, it should be stripped off too before using the striped filename as title for a scraper but the default
CleanStringRegExps only contains values up to Blu-ray format.
(2021-01-21, 13:44)jjd-uk Wrote: [ -> ]Media flags in the skin use data from either the library database or filename, as detailed on the wiki page https://kodi.wiki/view/Media_flags the video and audio flags come from stream details held in the library database, and media source flags come from the filename. So 4K is a video stream property that is held in the database, and UHD Blu-ray would be a media source flag that needs comes from the filename.
If we only have
Media source flags in case of Media stubs, we only have it up to Blu-ray but not for UHD.
In my understanding we cannot bring
Video and
Audio flags into the database, since we only have the stub filename (and following your statement: only Media source flags are supported).
The example
Media Tags / Flags is for a
.mkv file but shouldn't this also be valid for stub files?
However, the text for the flags is still missing (you can only guess what the correct strings are).
(2021-01-21, 13:44)jjd-uk Wrote: [ -> ]The stream details are provided to the skin by standard infolabels see https://kodi.wiki/view/InfoLabels and it's up to each skin to decide which ones they want to show for the audio/video properties, in the case of Estuary then up to 8K is support for the video resolution flagging, see https://github.com/xbmc/xbmc/tree/master...resolution
When it comes to flags for media sources such as DVD or UHD Blu-ray it's up to each skin to implement the extraction from the filename and up to now this hasn't been done for Estuary.
"stream details": It's somehow confusing since we have no "stream" in case of media stubs, I think.
Okay, as video resolution flags we have them up to 8K. This is fine. However, I don't know how to use them in stub filenames, if e.g. "4K" and "8K" are not stripped off by CleanStringRegExps. Maybe a possible solution might (only) be to use mixed NFO files, including a URL for the scraper.
I think Kodi core has to support everything of the InfoLabels independently from support in skins, also when it comes to strip off something from a filename.
(2021-01-21, 13:44)jjd-uk Wrote: [ -> ]I plan on taking a look at improving media flags for Estuary in v20 and adding flags for media sources is on my list of things to look at.
This sounds fine (better late than never).
Maybe it works already somehow but maybe some better support is still missing (e.g. in Estuary). Maybe also the Wiki is not as clear as it could/should be (and it seems to be not up to date at all).
