Under skin settings/media view, there is a setting for Use New Media Views Selector. When setting to Yes, it shows Missing Add-on, No Information Available. Which add-on is missing?
When using Artist Slideshow, it appears that the fadetime is set to 10000 (I think default is 400). I changed it manually in MusicVisualization but was wondering if there is a setting for it that I couldn’t find?
(2021-01-25, 16:46)Ingme Wrote: [ -> ]Under skin settings/media view, there is a setting for Use New Media Views Selector. When setting to Yes, it shows Missing Add-on, No Information Available. Which add-on is missing?
Ingme , the missing addon is script.skinvariables. You can get a recent version (the one in the Kodi repo is too old) from
https://github.com/jurialmunkey/script.skinvariables . The master branch is for Leia, and there is a Matrix branch as well.
As for the fadetime, I have not made that configurable for Artist Slideshow fanart. What value did you change it to, and what values do you think are appropriate as options? Thanks.
Regards,
Bart
(2021-01-25, 22:02)Ingme Wrote: [ -> ] (2021-01-25, 21:09)bsoriano Wrote: [ -> ] (2021-01-25, 16:46)Ingme Wrote: [ -> ]Under skin settings/media view, there is a setting for Use New Media Views Selector. When setting to Yes, it shows Missing Add-on, No Information Available. Which add-on is missing?
@Ingme , the missing addon is script.skinvariables. You can get a recent version (the one in the Kodi repo is too old) from https://github.com/jurialmunkey/script.skinvariables . The master branch is for Leia, and there is a Matrix branch as well.
Regards,
Bart
Now works with that add-on, thanks.
Fadetime: If there isn’t a setting for it now, I’m not sure it’s worth the time adding an option to change it. I didn’t notice anyone else wanting to change it and I didn’t see that option in other skins so a default value is probably sufficient. But Amber’s default time is 10000 (10 sec) which is a bit long. The Artist Slideshow Wiki example uses 400 but I have seen a couple of other skins go as high as 600 or 900 (I quickly used 800 but it’s really just personal preference).
Ingme , thanks for the additional feedback. You are correct about the fadetime being very long, I had not noticed since I do not listen to music that much with Kodi. I went ahead and set it at 800 now. The changes are on GitHub only at this time.
Regards,
Bart
