2021-07-07, 11:59
2021-07-07, 13:00
There is no timer functionality in any of the Kodi versions that will make it reset itself. The reset option itself is also totally absent.
So either you have installed a very destructive add-on on both Kodi setups, or there is some exterior threat that is messing with Kodi.
2021-07-07, 13:15
(2021-07-07, 13:00)Klojum Wrote: [ -> ]There is no timer functionality in any of the Kodi versions that will make it reset itself. The reset option itself is also totally absent.
Than it should be an exterior threat on my windows system because i don't have add ons. But my windows system is clean, no special programs. Just the windows installation, firefox, kodi and nenwleecher extra installed.
2021-07-07, 15:39
What do you mean by "resets itself"? Crashes? Goes back to default settings, wiping your settings and your database?
2021-07-07, 16:00
(2021-07-07, 15:39)ashlar Wrote: [ -> ]What do you mean by "resets itself"? Crashes? Goes back to default settings, wiping your settings and your database?
2021-07-07, 17:19
(2021-07-07, 16:00)dennis_n Wrote: [ -> ]Goes back to default settings
FYI, no one of us is setting next to you, so we cannot see what is happening.
So perhaps you can explain it, preferably with much more than 4 words.
File sources? Weather settings??
Which Kodi settings are being reset?
2021-07-07, 17:38
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
2.Restart Kodi
