kwirk
Read the Media Flags here
https://kodi.wiki/view/Media_flags
The skin only shows flags when the info is available in the Kodi Database, and sometimes needs to have information in the filename too like HDR, 10-bit flags for example.
Check the Kodi Media Settings - Videos
Widget Movies - Flags ok here
Library Mode View
hello
in Music i can not find party mode.
to play random songs
xbmcwood
Party mode is available in the music submenu, look at the image.
(2023-06-04, 05:21)Wanilton Wrote: [ -> ]@xbmcwood
how do i open music sub menu windows 10
xbmcwood
Main Menu Music Item - Press the down arrow twice (2x), and you are done. The first arrow down goes to fast edit, the second goes to the submenu area. If you don´t use Fast Edit, it is possible to disable the feature, Go to Skin Settings -> Main Menu - turn off Show Quick Edit Menu./
Here is the fast edit (music)
I have Kodi 20.1 on my firestick 4k max. I have really enjoyed getting to know and learn all about MQ 9. I absolutely love it.
However, a feature that seems to no longer be available, and is not specific to MQ 9 seems to no longer be available. That is the scroll bar transitioning to scroll by alphabet.
I have a second firestick with Kodi 20.1. This is the regular Kodi install with no different skin being applied yet.
It used to be, on both, I could click the down button once and would bring up a scroll bar. If I click a second time it would bring up the letter of the alphabet I am in for my movies or TV shows and scroll from a to b to c and so on. Then if I click it a 3rd time, it would display the background are alone.
Now if I click once it will go to a scroll bar that seems to scroll just by a select number of videos but not by alphabetical letters. And then click a 2nd time and it gives me the ba kgrou d artwork. I ha e searched high and low in both kodi skins as well as this forum and Google and I cannot find the answer of where the options are to change the scroll to move by alphabet.
Any help would be appreciated. Thanks!
davelee77
MQ9 does not natively support this function. Probably new features like the one requested only in MQ10, or if someone creates an MQ9 mod bringing such a feature in the skin.
(2023-06-08, 12:52)Wanilton Wrote: [ -> ]@davelee77
That is interesting as I could have swore it worked when I first started using it before. Well hopefully they add it tothis skin.
Although I AM under MQ 9 topic, I did mention this is also happening in in Kodi 20.1 Nexus with the, I think it's called, Estuary skin? The one that Kodi normally starts with standard. Any thoughts on that one quick? I know for a fact it worked there and in Aeon Nox Silva but the same thing is happening.
Thanks for your help!
Is IPTV Client necessary if I am using Audio Nodes and not the true Radio feature? I couldn't get Radio to work but the Audio Nodes through the Radio add-on seem to work just fine. If I don't need the IPTV Client, I can eleminate the error message that it didn't connect. Please advise. Thank you.
davelee77
Sorry, I don´t enough info to say something about it.
(2023-06-09, 15:50)Wanilton Wrote: [ -> ]@davelee77
I respect that. Hopefully someone will. lol For the most part, I've figured a lot of things out about Kodi but I decided to venture into the radio and live TV stuff and it's a little rough around the edges. I did figure out how to find all my favorite radio stations and even those I was told I wouldn't be able to do because they do their html and data in packs instead of a single url. lol
Appreciate your help on the other stuff though. Glad we have good support here.
(2023-06-09, 15:57)davelee77 Wrote: [ -> ] (2023-06-09, 15:50)Wanilton Wrote: [ -> ]@davelee77
... and even those I was told I wouldn't be able to do because they do their html and data in packs instead of a single url. lol ....
nice, you found a way to do the other ones
i only told you the method i gave you wouldnt work though -
https://forum.kodi.tv/showthread.php?tid...pid3153113
Hey guys! Having a very minor issue in view 06. Where it asks to "View Panel" Automatic and manual don't seem to work. I have to hit "M" to bring up top menu and change back to automatic. I know I could just hit "I" for full info, but when scrolling through collection, I kinda miss hitting up to get a brief outline. Any suggestion? I've settled for "Always On" for now, but would like the option. Any Help?
RonnieG3
Thanks for inform the bug, need fix, I will inform MarcosQui about it.
Suggesting the option for alphabet jump or alphabet scroll be added in next skin release for movies and tv shows. I was given a link to try and add it from a zip file. I made the attempt but was getting an error message in Kodi with this skin. I assume because it isn't compatible with this skin, version of Kodi or because the files themselves might not be up to date. I also tried to decompress file on my laptop and there are files in there.
https://github.com/kodi-community-addons...habet-Jump
Script.Skin.Helper.Service-1.0.11.zip
Error Message: "Failed to install add-on from zip file. The dependency on xbmc.python version 2.13.0 could not be satisfied."
If you could include this or have a way for it to be added, I personally think it would be helpful. Thank you.
Otherwise, everything else about the skin, I love and does everything I had hoped for and more.
