Excellent work Frosty.
Latest t3ch build and Frostys`
http://trac.xbmc.org/ticket/4905 patch applied.
Not yet merged.
With the new addition of Frostys` patches to the Xbox code the xbox catches up to it`s younger siblings.
Southpark studios - nearly done & working.
BBC iplayer - working.
Hulu - being re-played with.
Any more folks , the field is open ?
Voinage,
could you be so kind and explain how to implemet the latest Patch as it seems that the T3ch Built from 19.09. has not yet had that Patch included.
THX
Pt-1
you apply the diff. you compile. no magic to it
Apologize again if my reply has not been 100% .
I am aware on how to do this on the Tuxbox Dbox Project but I always understood that for the old XboX hardware this would be not "Legal" and read Voinage orginal Post as there is a way to use the latest T3ch built and "add" a ready compiled file to it to make it work.
If not I am more that happy to stop asking questions and wait with everyone else for the next T3ch release.
THX
PT-1
"With the new addition of Frostys` patches to the Xbox code the xbox catches up to it`s younger siblings."
WOOOOOOP WOOOOOP!!
Well in fellas!!!! Voinage and Frosty!! could be a legendary team!
I might have to wait until its merged as not really sure how to apply patches..
Is this the same Frosty that made the Xbox recovery and vga disk/patches?
All Frostys' work - Thank him,i just make plugins.
how and where do you apply this patch on the xbox? and what is rtmp anyways?
it says...
lord fluffy Wrote:how and where do you apply this patch on the xbox? and what is rtmp anyways?
I read: "Please hand it all to me on a plate because I can't even use Google search"
From Google:
Real Time Messaging Protocol (RTMP) is a proprietary protocol developed by Adobe Systems for streaming audio, video and data over the Internet, between a Flash player and a server.
From T3ch changelog:
2008-09-14 15561 fixed: Ticket #4498 - RTMP support backport to XBMC for Xbox, thanks to frosty
(no need to patch now)
there is a need to apply the second patch Frosty has come up with the first is all ready committed and in the TC3H release.
I stand corrected. Thanks Marlboro
thank you oh so much marlboroman1 for clearing things up with this patch fix!!!
i read your comments on xbmctrac and you mentioned that you copied and pasted the two parts of the patch, saved them, and applied the patch successfully.
just a few questions...what should you name the patch in notepad and where would you place the patch in xbmc?
lord fluffy Wrote:i read your comments on xbmctrac and you mentioned that you copied and pasted the two parts of the patch, saved them
that was what I was doing wrong. you need to just down load the patch as it is the link is at the bottom of the page and apply it to the svn before building.
if your not already building from source code regularly its probably best to wait for it to be included in a official build.
Lord Fluffy,
This is for people who are compiling the xbox builds from source using the XDK, and the patch is applied to the SVN.
...So, you and I will have to wait for the next T3CH.
... but
also.
-Wes
Gamester17 Wrote:Previous requested RTMP video stream sites:
TED.com
http://forum.xbmc.org/showthread.php?tid=32165
As I noted in that thread, TED.com doesn't need rtmp. Everything is available as regular streaming .mp4 via rss. Plus, it's already in Navi-X and I made a dedicated plugin for it.
