Full Version: How does Kodi make Dolby Vision 7 movies work?
I have been trying to get Jellyfin to play a DV 7 movie on a 4k Chromecast (newest version). I read that Kodi converts it on the fly (wtf?) so I tried, and somehow it works. I am streaming the same movie from a jellyfin server to kodi on chromecast, and it works. On the jellyfin client, it won't work. All my DV7 movies won't work, but movies with same codecs, bits, resolution, etc will work. Examples below:
I'm hoping someone here might be able to summarize how Kodi can play DV7?
DOES PLAY:
Title: 4K HEVC HDR
Codec: HEVC
Profile: Main 10
Level: 153
Resolution: 3840x2160
Aspect ratio: 16:9
Interlaced: No
Framerate: 23.976025
Bitrate: 59669 kbps
Bit depth: 10 bit
Video range: HDR
Video range type: HDR10
Color space: bt2020nc
Color transfer: smpte2084
Color primaries: bt2020
Pixel format: yuv420p10le
Ref frames: 1
DOES NOT PLAY:
Title: 4K HEVC HDR
Codec: HEVC
Profile: Main 10
Level: 153
Aspect ratio: 16:9
Interlaced: No
Bitrate: 61054 kbps
Bit depth: 10 bit
Video range: HDR
DV title: DV Profile 7.6
DV version major: 1
DV version minor: 0
DV profile: 7
DV level: 6
DV rpu preset flag: 1
DV el preset flag: 1
DV bl preset flag: 1
DV bl signal compatibility id: 6
Ref frames: 1
The following commit by quietvoid implemented the conversion via libdovi https://github.com/xbmc/xbmc/pull/22546/...4d0113f584
https://github.com/quietvoid/dovi_tool
