interesting
does not work, presumably because it is returng the icon path, so maybe a new infolabel
PHP Code:
<control type="largeimage">
<posx>0</posx>
<posy>0</posy>
<width>1280</width>
<height>720</height>
<onclick>-</onclick>
<texture>$INFO[Weather.Conditions,http://xbmc-addons.googlecode.com/svn/packages/skin/,.jpg]</texture>
</control>
works
PHP Code:
<posx>0</posx>
<posy>0</posy>
<width>1280</width>
<texture>http://xbmc-addons.googlecode.com/svn/packages/skin/Cloudy.jpg</texture>
</control>
Timdog, that link isn't exactly correct. It's from NOAA not Weather.com
The weather.com scraper automatically returns an icon number which is associated to an icon in XBMC's zip file.
In addition to getting an INFO label it would help to somehow get a condition = number list but I'm not sure if that's possible.
If you want to play around with the scraper I have found this works:
Replace 59901 with any zip code.
http://xoap.weather.com/weather/local/59...145f208494
I couldn't get the largeimage to work correctly either.
PHP Code:
<posx>0</posx>
<posy>0</posy>
<width>720</width>
<height>576</height>
<texture>$INFO[Weather.Conditions,Weather]</texture>
</control>
This thread has been a great read, and to the advanced user it probably makes a lot of sense. A lot of if it is flying way over my head
So for all keen learners can someone explain how it is implemented using the latest t3ch svn, i.e a tutorial, or some basic steps at least. Also what skin would this work with? PM3HD, Mediastream....
Quote:
added: Weather.FanartCode infolabel (returns the condition icon value eg Mostly Cloudy = 28)
I think this is the best you can get without a bunch of unnecessary code. it does mean you will have different codes for night and day.
PHP Code:
<posx>0</posx>
<posy>0</posy>
<width>1280</width>
<texture>$INFO[Weather.FanartCode,http://xbmc-addons.googlecode.com/svn/packages/skin/,.jpg]</texture>
</control>
works fine
found this, not sure how accurate
Quote:
N/A Not Available
00 Rain/Lightning
01 Windy/Rain
02 Same as 01
03 Same as 00
04 Same as 00
05 Cloudy/Snow-Rain Mix
06 Hail
07 Icy/Clouds Rain-Snow
08 Icy/Haze Rain
09 Haze/Rain
10 Icy/Rain
11 Light Rain
12 Moderate Rain
13 Cloudy/Flurries
14 Same as 13
15 Flurries
16 Same as 13
17 Same as 00
18 Same as 00
19 Dust
20 Fog
21 Haze
22 Smoke
23 Windy
24 Same as 23
25 Frigid
26 Mostly Cloudy
27 Mostly Cloudy/Night
28 Mostly Cloudy/Sunny
29 Partly Cloudy/Night
30 Partly Cloudy/Day
31 Clear/Night
32 Clear/Day
33 Hazy/Night
34 Hazy/Day
35 Same as 00
36 Hot!
37 Lightning/Day
38 Lightning
39 Rain/Day
40 Rain
41 Snow
42 Same as 41
43 Windy/Snow
44 Same as 30
45 Rain/Night
46 Snow/Night
47 Thunder Showers/Night
@nuka
What are the chances of being able to use a live feed for weather fanart? I know there are tons of webcams set up in cities all over the world. The only issue would be quality. From what I have seen, most of the video is pretty much crap. However, some of the time lapse stills are pretty decent quality. It would be cool to buy a decent web cam and put it up in a window at your house. Then you could get live video of local weather conditions.
If we got enough users to purchase decent cameras we could set up a network of high quality weather feeds from around the globe. I don't think video would be possible due to bandwidth limitations, but really nice time lapse stills would be totally doable.
you may already be able to with time lapse
just use a
</texture>urltowebcam</texture>
FYI; further development discussion and ideas about adding on-the-fly theme/backdrops changes to skins with variables based and weather conditions (and also based on the date and time of the day) can be found here:
http://forum.xbmc.org/showthread.php?tid=27354
So I'm having some troubles getting this info label to work.
I have an option to set the folder to their weather images in skin options.
Then to display the images I am using:
$INFO[Skin.String(WeatherFanart_Path)]$INFO[Weather.FanartCode]
As a result, the images are displayed randomly but not by current weather condition.
Basically it's acting like I only am using $INFO[Skin.String(WeatherFanart_Path)].
Hope this makes sense.
Any thoughts?
sounds like you don't have an updated xbmc. that is if the multiimage is recursive.
meaning FanartCode is returning a blank.
Nuka1195 Wrote:sounds like you don't have an updated xbmc. that is if the multiimage is recursive.
No, I have the latest XBMC.
It works using a direct link
c:/XBMC/Weather/$INFO[Weather.FanartCode] but not using the my info label above.
Maybe I have the info label incorrect?
Check out latest XBMC Connected and you will see what I am talking about.
In Weather Skin Options you can set the folder path.
nothing in your pal/MyWeather.xml has fanart in it. i did a search
nm, it's in includes.xml
the labels have the right image, but i get no images showing at all.
i made the control alway visible and it shows and appears to show the correct images.
edit: <colordiffuse>DisabledTextColor</colordiffuse> makes the images not show
Figured it out. I was missing a comma in between the statements
,]$INFO[Weather.FanartCode]
Before it was showing any random image. Now it's showing them based on weather condition.
