weird as that doesn't make sense.
the comma would only be needed if you nested the $INFO[] items.
$INFO[Skin.String(WeatherFanart_Path),,$INFO[Weather.FanartCode]]
Hi all u experts are doing great work. But unless the newbies can use it the whole development gets limited only to the select circle.
I love ur work and would like to use it. I am using Focus alpha 6 skin. Can someone please explain the codes to be used and in what files and where.
I tried putting the codes as timdog82001 mentioned in my home.xml and myweather.xml files but didn't work. I have the images downloaded in the xbox "C:\Images\weather\"
Thanks in adv for all help
post the exact code you used and you'll be more likely to get some help.
Wir3d Wrote:So I'm having some troubles getting this info label to work.
I have an option to set the folder to their weather images in skin options.
Then to display the images I am using:
$INFO[Skin.String(WeatherFanart_Path)]$INFO[Weather.FanartCode]
As a result, the images are displayed randomly but not by current weather condition.
Basically it's acting like I only am using $INFO[Skin.String(WeatherFanart_Path)].
Hope this makes sense.
Any thoughts?
hi im also new here - really great work
at least i managed to display the images randomly as above
where in myweather file should i put this string
$INFO[Skin.String(WeatherFanart_Path),]$INFO[Weather.FanartCode]
