It's still not working for me.
Log:
http://pastebin.com/m385a1390
19:45:04 T:4556 M:1482973184 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting smb://TOWER1/Movies/The Wrestler/
19:45:04 T:4556 M:1482969088 DEBUG: Thread 4556 terminating
19:45:04 T:1288 M:1480953856 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting smb://TOWER1/Movies/Youngblood/
19:45:04 T:1288 M:1480949760 DEBUG: Thread 1288 terminating
Those two movies are the ones that are gone from the server and should have been cleaned.
Can someone please confirm this so the devs might investigate further. I've tried my existing db, I nuked it and started over, and I've done this on two different machines and clean on update doesn't work in any scenario. I can't be the only one can i?
I think your best bet to get attention from the devs would be to comment on the tracker
RockDawg Wrote:Can someone please confirm this so the devs might investigate further. I've tried my existing db, I nuked it and started over, and I've done this on two different machines and clean on update doesn't work in any scenario. I can't be the only one can i?
You're not the only one. It's not working for me either.
i need exact reproducing instructions. i do not have time to both find the bugs and fix them
Well in my case, my movies are in subfolders with "use folder nanes for lookups enabled". If i delete a movie folder and then in movie library do library update, it won't cleanup.
Tv shows seem to clean up properly.
http://koti.kainuu.com/manki/xbmc.log
Titanic (:o) is a nonexistent folder in that log.
toiva Wrote:Well in my case, my movies are in subfolders with "use folder nanes for lookups enabled". If i delete a movie folder and then in movie library do library update, it won't cleanup.
Thanks for the confirmation toiva. I was going to update the ticket on the tracker, but I got busy plus I wanted to do more testing to be sure of the problem re-opening a ticket. I get the exact same as toiva. TV Shows clean fine, but movies don't. I also have my movies stored in individual folders. I just tried nuking the db and I created some dummy files to see if it's related to folders or if indeed individual files have the same problem. After scanning the dummy files and then removing one, update library does not remove the missing movie. I have attached a log that is with the dummy files since you already have a couple with movies in folders.
Log:
http://pastebin.com/m38852b86
I'm certainly no expert, but this line would seem to indicate that it knows the contents have changed, but it still doesn't do anything for some reason:
[CODE]Hash[movies,smb://KEVIN-DESKTOP/Users/Kevin/Videos/]
B=[141C82A9E6423872CDD40ED5B46BB9AC],Computed=[6B12344BB4E29E6DADC6637D585B8EEE]/CODE]
spiff Wrote:r20289. cheers.
No, cheers to you for the fix! I'll be sure to verify as soon as there's a Win build available that includes this revision. Thanks again!
RockDawg Wrote:No, cheers to you for the fix! I'll be sure to verify as soon as there's a Win build available that includes this revision. Thanks again!
Okay, new build on the way.
It seems to be fixed for single file movies, but not foldered movies. I've tried both. Here is a log after I updated the library consisting of foldered movies:
http://pastebin.com/m6c20b534
The missing movie in my case is Youngblood and as you can see, it shows an error finding it, but it is not removed from the library.
Quote:16:50:33 T:2360 M:983691264 ERROR: DIRECTORY::CDirectory::GetDirectory - Error getting smb://TOWER1/Movies/Youngblood/
P.S. Thanks for the quick build kricker even though it took me a while to get back on this.
Bumping in case this got lost in the shuffle.
I've done some more testing on this and I have noticed something. It only does it with movies that have the standard DVD file structure. I've tried single file movies (.avi, .mpg, .wmv, .mkv) and they update correctly. Here's a relevant log where the update removed the missing movie:
http://pastebin.com/m2776ad0d
Also, I then put those same single file movies within individual folders and enabled "Use folder names for lookups" on the initial scan. After deleting one the the folders (and it's accompanying movie file), running update library did indeed remove the missing movie from the db. Here is a log that shows that:
http://pastebin.com/m745b1b05
But whenever I make it so that the movies are folders containing VIDEO_TS.ifo, updates refuse to clean the library of missing movies.
