2009-06-01, 11:05
2009-07-22, 09:17
PBS changed their urls from http://www.pbs.org/video to http://video.pbs.org. Below is a fixed version of the plugin for this change.
http://www.diveopolis.com/PBS Video.zip
2009-07-22, 10:20
[Update 7/22/09 v1.1]
- updated regex and urls to work with site changes - thanks bolt
- added video info to video play back
- added plugin category title
- added update checker
- fixed library mode problem
Now on SVN Repo Installer...
2009-08-13, 01:20
[Update 8/12/09 v1.2]
- updated plugin to work with pbs.org changes
2009-08-23, 14:21
stacked Wrote:[Update 8/12/09 v1.2]
This isn't working for me at all now, it doesn't retrieve anything. Any idea why that might be?
Thanks in advance,
~c
2009-08-23, 21:26
chad_ Wrote:This isn't working for me at all now, it doesn't retrieve anything. Any idea why that might be?
Thanks in advance,
~c
[Update 8/23/09 v1.3]
- updated plugin to work with pbs.org changes (again)
- added plot/summary to info labels
2009-08-24, 02:43
I can confirm that the 1.3 update runs on XBMC for Xbox (6-27 T3CH build), as of Aug 23, 2009. Tested by listing shows for several programs, and initiating playback for 3 different programs.
p.s. My only complaints, now, are with typical stream control limitations and the Xbox CPU, not the plugin. The plugin is slow to respond to Stop/Pause/Play commands, taking upwards of 15 seconds to end when the Stop button is pressed, and, of course, there's no FF, Rew, Skip-Ahead, Skip-Back, or ability to resume from previous position.
(Again, thanks.)
p.p.s. I've just started trying to use plugins and scripts again, and wanted to say that the ability to see the show info and description via the Info button is great. (I don't know if it's unique to this plugin, so am generally appreciative.)
(Again, thanks.)
2009-08-24, 04:07
Quote:p.s. My only complaints, now, are with typical stream control limitations and the Xbox CPU, not the plugin. The plugin is slow to respond to Stop/Pause/Play commands, taking upwards of 15 seconds to end when the Stop button is pressed, and, of course, there's no FF, Rew, Skip-Ahead, Skip-Back, or ability to resume from previous position.
(Again, thanks.)
Yea, that kinda sucks but there is nothing I can do about it. I guess the combination of the rtmp and the high quality videos is too much for the xbox.
Quote:p.p.s. I've just started trying to use plugins and scripts again, and wanted to say that the ability to see the show info and description via the Info button is great. (I don't know if it's unique to this plugin, so am generally appreciative.)
Thanks. This can be done in any plugin, it's just up to the plugin author to add it. I just found out about a few weeks ago and I've been trying to add this functionality to all my plugins.
2009-08-24, 07:38
So does PBS keep changing things specifically in order to keep things like this from working, or is it something else?
This is a frustration with all of the recent scripts and plugins:
Hulu, YouTube, etc.
It's getting ridiculous playing this cat-and-mouse game of having to constantly update our plugins/scripts when they change their site for whatever reason...
-Wes
Hulu, YouTube, etc.
-Wes
2009-08-24, 07:54
waldo22 Wrote:So does PBS keep changing things specifically in order to keep things like this from working, or is it something else?
Hulu, YouTube, etc.
-Wes
Yea, its getting annoying. Some sites seem to be changing a few lines every couple of days.
2009-11-25, 01:21
I'm using the packages from the ppa here
https://launchpad.net/%7Eteam-xbmc/+archive/karmic-ppa
I see this in the xbmc.log
It fails to launch the script. Any ideas?
Greg
15:12:50 T:139801016817936 M:7282442240 NOTICE: Traceback (most recent call last):
15:12:50 T:139801016817936 M:7282442240 NOTICE: File "/home/ghulands/.xbmc/scripts/PBS Video/default.py", line 138, in ?
15:12:50 T:139801016817936 M:7282442240 NOTICE: params=get_params()
15:12:50 T:139801016817936 M:7282442240 NOTICE: File "/home/ghulands/.xbmc/scripts/PBS Video/default.py", line 122, in get_params
15:12:50 T:139801016817936 M:7282442240 NOTICE: paramstring=sys.argv[2]
15:12:50 T:139801016817936 M:7282442240 NOTICE: AttributeError
15:12:50 T:139801016817936 M:7282442240 NOTICE: :
15:12:50 T:139801016817936 M:7282442240 NOTICE: 'module' object has no attribute 'argv'
15:12:50 T:139801016817936 M:7282442240 ERROR: Scriptresult: Error
Greg
2009-11-25, 09:31
I'll that a look.
2010-01-25, 21:49
[Update v1.3.1 - 1/25/10]
- Fixed error causing some directories not to load (eg. FRONTLINE)
Let me know if there any other problems.
2010-03-27, 21:05
The plug in had been working until recently; the directory of shows loads but upon trying to retrieve a show, you get a failure due to script error. Any help(NT: running on Apple TV)
2010-03-27, 22:34
doctordeck Wrote:The plug in had been working until recently; the directory of shows loads but upon trying to retrieve a show, you get a failure due to script error. Any help(NT: running on Apple TV)
[Update v1.3.2 - 3/27/10]
- Updated plugin to work with PBS recent changes. Fixes video loading error.
