2011-01-13, 05:09
2011-01-14, 15:01
I give thanks too. This and Pandora are easily my favorite XBMC plugins.
2011-02-08, 22:14
Update - Version 1.0.3
- Added duration to the video listings
- Fixed video summary issue under the search menu
- Added support for HTTP 404 and HTTP 503 errors
- Video clips now start at the appropriate time
P.S: Please report any videos not playing.
The update will be posted as soon as it's approved.
2011-02-13, 22:33
I finally upgraded XBMC Live from 28256 to 35648 and with that also added the add-on for PBS
Nearly everything works awesome and Austin City Limits plays as well but has no audio. Very wierd because everything thing else within XBMC has audio. Movies, RSS feeds, and all PBS programs but the Austin City Limits.
I had the System Audio setting on analog and switched it to HDMI, but the results was the same. I tried 3 different Austin City Limit's programs and no sound form any of them. Is this Weird or what. I am beginning to think one of my college Prof's was right when he told me all of computer science is 'pure FM'.
do you have any ideas?
2011-02-14, 00:24
sar_scarab Wrote:I finally upgraded XBMC Live from 28256 to 35648 and with that also added the add-on for PBS
I found one video playing without audio. When I went to the website, the same video still didn't have audio. It must be a problem with the video.
Sample video: Allen Toussaint - http://video.pbs.org/video/1780862774
Here is Austin City Limits page. Go through it and compare the videos you are having problems with. If it doesn't have audio on the site, it most likely won't have audio on XBMC.
http://video.pbs.org/program/1273976454/
2011-02-14, 03:10
I'll get back on that tonight. This is what I tried to play and it had no video.
PBS_CP_Austin_City_Limits/3611_bandofhorses_otl_COVE.mp4
PBS_CP_Austin_City_Limits/3613_lovett_nf_COVE.mp4
Those items above were taken from the xbmc.log file
2011-03-20, 08:57
There seems to be a lot of videos that are not streaming in the PBS Video Add-on. Specifically, this is the error I get when I try to stream NOVA videos, for example:
"Script failed! : plugin.video.pbs"
Does anyone know how to fix this, or point me in the right direction if there is a fix?
Thanks in advance!
Thanks in advance!
2011-03-20, 13:00
I just tried a few Nova videos and they loaded up videos fine.
You'll need to provide a debug log for anyone to be able to figure out what the issue (if any) might be.
2011-03-22, 13:57
Thanks for the reply! So sorry, but how do I go about recording a log and pasting it? I'm pretty sure it has been discussed before, but if you could just guide me, I can provide the error ASAP
Hinz
2011-03-23, 18:18
Check under Topics/Technology
Tons of vidoes don't work. Most get "Script failed! : plugin.video.pbs" while other tries to load for about 1 second and then the loading icon just vanish, without any error message.
Here's a log where I try some of the videos: http://pastebin.ubuntu.com/584362/
2011-04-22, 17:24
I get 'script failed' when trying to play most videos.
2011-04-22, 22:41
Hi, installed the PBS add-on but get the following errors when I try to watch any video:
21:41:31 T:8152 M:2393378816 ERROR: Error Type: exceptions.IndexError
21:41:31 T:8152 M:2393378816 ERROR: Error Contents: list index out of range
21:41:31 T:8152 M:2393378816 ERROR: Traceback (most recent call last):
File "C:\Users\home theatre\AppData\Roaming\XBMC\addons\plugin.video.pbs\default.py", line 283, in ?
play_video( name, url, thumb, plot, studio, starttime )
File "C:\Users\home theatre\AppData\Roaming\XBMC\addons\plugin.video.pbs\default.py", line 192, in play_video
src = re.compile( '<ref src="(.+?)" title="(.+?)" author' ).findall( data )[0][0]
IndexError: list index out of range
Any updates/insights would be appreciated...
2011-04-25, 22:03
jsttesting Wrote:There seems to be a lot of videos that are not streaming in the PBS Video Add-on. Specifically, this is the error I get when I try to stream NOVA videos, for example:
Thanks in advance!
Hinz Wrote:Check under Topics/Technology
Talus Wrote:I get 'script failed' when trying to play most videos.
nhoj Wrote:Hi, installed the PBS add-on but get the following errors when I try to watch any video:
Can you guys download the update and let me know if all the problems were fixed?
Download the zip and install it manually:
https://github.com/stacked/plugin.video.pbs
Once all the bugs are confirmed fixed, I'll release it to the official xbmc addon repo.
2011-04-28, 21:24
I've downloaded the updated .zip from the link above but I'm still having an issue watching some videos. Here is the relevant bit from the logs:
Let me know if you like any more debugging information.
20:24:04 T:2776955760 M:1792720896 NOTICE: -->Python Interpreter Initialized<--
20:24:05 T:2776955760 M:1791705088 NOTICE: PBS - URL: http://video.pbs.org/xbmc/1415190951
20:24:06 T:2776955760 M:1791578112 NOTICE: PBS - URL: http://release.theplatform.com/content.select?pid=t1z3p0wn0Yp_QBjCfleXxBmMHapI4ZTx&format=SMIL
20:24:06 T:2776955760 M:1791578112 ERROR: Error Type: exceptions.IndexError
20:24:06 T:2776955760 M:1791578112 ERROR: Error Contents: list index out of range
20:24:06 T:2776955760 M:1791578112 ERROR: Traceback (most recent call last):
File "/home/pvr/.xbmc/addons/stacked-plugin.video.pbs-46ef806/default.py", line 285, in ?
File "/home/pvr/.xbmc/addons/stacked-plugin.video.pbs-46ef806/default.py", line 195, in play_video
2011-04-29, 00:46
warpzero Wrote:I've downloaded the updated .zip from the link above but I'm still having an issue watching some videos. Here is the relevant bit from the logs:
Code:20:24:04 T:2776955760 M:1792720896 NOTICE: -->Python Interpreter Initialized<--
Are you in the US?
Download this file, open it with Notepad, and paste it here:
http://release.theplatform.com/content.s...ormat=SMIL
I also need the entire debug log.
