2009-02-02, 13:51
What can be wrong here? Other seems to use the same motherboard and gfx, and doesnt have the same problem.
Low FPS => playback is like slow motion..
/Söder
/Söder
NEI Wrote:I installed newest driver with newest svn xbmc and have a 780g chipset with ati HD-3450 graphics last weekend and I have none of your problems. Try to set Vsync in amdcccle to Quality (slider all to the right) and then disable VSync in XBMC...
Good luck...
Section "ServerLayout"
Identifier "aticonfig Layout"
Screen 0 "aticonfig-Screen[0]-0" 0 0
EndSection
Section "Files"
EndSection
Section "Module"
Load "glx"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]-0"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver "fglrx"
Option "EnableMonitor" "nocrt1,tmds2i"
Option "DisplaySetup" "vertical"
BusID "PCI:1:5:0"
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-0"
Device "aticonfig-Device[0]-0"
Monitor "aticonfig-Monitor[0]-0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
EndSubSection
EndSection
soder Wrote:Well, Vsync in amdcccle I have solved. No tearings.
My problems are some:
1. WHEN I try the newer versions of the drivers, now the Cat 9.1, my XBMC have very low fps, making my videos lock like slow motion.
Dont know WHAT causing this.
2. I want to go back to the driver Ubuntu can install 8.552, from package manager. I dont know if thats svn or what svn stands for?
The problem here is that I no longer have any /usr/share/ati/amdpcsdb, the file where all the setting fron the cccp was stored, and I dont know how to create a new. And stange are, that the option I set seems to be stored some place else, but I dont know why. Its not in xorg.conf..and I have no amdpcsdb...
/Söder
hal2100 Wrote:.
#!/bin/sh
aticonfig --set-dispattrib=tmds2i,positionX:0
aticonfig --set-dispattrib=tmds2i,positionY:0
aticonfig --set-dispattrib=tmds2i,sizeX:1280
aticonfig --set-dispattrib=tmds2i,sizeY:720
AMDPCSDBV1
[AMDPCSROOT/SYSTEM/MCIL]
PXACAutoSwitch=V0
PXDCAutoSwitch=V0
CVRULE_CUSTOMIZEDMODESENABLED=V1
DFP_AddHDTVPixelFormats=V2
DALLinuxSupport=V1
DALNonStandardModesBCD=R140010500000006017921344000000601800144000000060185613920000006016001200000000601280076800000060144009000000006012800960000000601680105000000060
DALRULE_ADDNATIVEMODESTOMODETABLE=V1
DALRULE_ALLOWMONITORRANGELIMITMODESCRT=V0
DALRULE_DYNAMICMODESUPPORT=V1
DALRULE_GetLCDFakeEDID=V1
DALRULE_GetTVFakeEDID=V1
DALRULE_NOFORCEBOOT=V1
DALRULE_POWERPLAYDISREGARDDISPLAY=V1
DALRULE_RESTRICTDISPLAYSBASEDONPANELRES=V0
DALRULE_REGISTRYACCESS=V1
GCORULE_FlickerWA=V1
GCORULE_LCDValidatePixelClkOnly=V1
GXOM5XDisableLaneSwitch=V1
R6LCD_RETURNALLBIOSMODES=V1
TVEnableOverscan=V1
UvdEnabled=V1
DigitalHDTVDefaultUnderscan=V0
[AMDPCSROOT/SYSTEM/2ID-1002-791E-0/DDX]
MultiviewEnabled=V1
MultiviewHeterogeneous=V1
[AMDPCSROOT/SYSTEM/2ID-1002-7941-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-796E-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-9610-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-9611-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-9614-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-7124-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-7105-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-710f-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-712e-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-712f-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-710e-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-7125-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-7104-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-940b-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-940a-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-940f-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-9447-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-7152-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-7172-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-7173-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-7153-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-71d2-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-71f2-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-71fa-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-71da-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-728c-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-72ac-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-95cc-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-958d-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-958c-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-9511-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-949c-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-949f-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-949e-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-9444-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-9446-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-9456-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-71bb-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-719b-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-95cd-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-95ce-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-95cf-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-3151-0/DDX]
MultiviewEnabled=V1
ForceMultiHead=V1
[AMDPCSROOT/SYSTEM/2ID-1002-9452-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/2ID-1002-9519-0/DDX]
MultiviewEnabled=V1
[AMDPCSROOT/SYSTEM/DDX]
OGLFMTA2R10G10B10Enable=V0
EnableRandR12=SFALSE
RequestMSI=SFALSE
[AMDPCSROOT/SYSTEM/DDX/RECENTMODE]
EnableRestore=V1
[AMDPCSROOT/SYSTEM/DDX/RECENTMODE/SCREEN00]
Width=V1280
Height=V720
Refresh=V60
[AMDPCSROOT/SYSTEM/DDX/tmds2i/attribute]
positionX=V0
positionY=V0
sizeX=V1280
sizeY=V720
[AMDPCSROOT/SYSTEM/BUSID-1:5:0-0/MCIL]
DALLastConnected=V0
DALR6 DFPI 2_MaxModeInfo=R000000008007000038040000000000003C000000
DAL_ACEspectReady=V0
DALLastSelected=V2
DALLastTypes=V129
DALObjectData0=R010000000100000000000000010000000100000000000000010000000100000000000000010000000100000000000000010000000200000000000000010000000200000000000000030000000200000001000000030000000200000001000000010000000100000000000000010000000100000000000000010000000100000000000000000000000000000000000000010000000200000000000000000000000000000000000000010000000200000000000000020000000000000001000000
DALSelectObjectData0=R010000000100000000000000010000000100000000000000010000000100000000000000010000000100000000000000010000000200000000000000010000000200000000000000030000000200000001000000030000000200000001000000010000000100000000000000010000000100000000000000010000000100000000000000000000000000000000000000010000000200000000000000000000000000000000000000010000000200000000000000020000000000000001000000
DALCurrentObjectData=R010000000200000000000000000000000000000000000000
DALInstallFlag=V1
DALR6 DFPI 21776x1000x0x60=R000000000000000000000000000000000000000000000000000000000000000000000000080000000100000001000000
DAL_DFP2ColorTemperatureSourceA934A081=R0000000064190000
DALR6 DFPI 2=R0000000000000000000000006400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000640000006419000000000000010000000000000000000000000000000000000000000000
DALR6 DFPI 21280x720x0x50=R000000000000000000000000000000000000000000000000000000000000000000000000080000000100000001000000
AsicOnLowPower=V0
DALR6 DFPI 21920x1080x0x60=R000000000000000000000000000000000000000000000000000000000000000000000000080000000100000001000000
DALR6 DFPI 21280x720x0x60=R000000000000000000000000000000000000000000000000000000000000000000000000080000000100000001000000
[AMDPCSROOT/SYSTEM/BUSID-1:5:0-0/OpenGL]
VSyncControl=V3
CatalystAI=V2
[AMDPCSROOT/SYSTEM/BUSID-1:5:0-0/LibXUtil/Display1]
Map=V128
Enable=V1
[AMDPCSROOT/SYSTEM/LibXUtil/Display1]
Map=V128
Enable=V1
[AMDPCSROOT/SYSTEM/LDC]
LastViewedPage=SMore Settings
LastSelectedDevice=S296:38416:4098:53248:5208|1
AMDPCSDBV1
PXACAutoSwitch=V0
PXDCAutoSwitch=V0
DALLinuxSupport=V1
TVEnableOverscan=V1
UvdEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
ForceMultiHead=V1
MultiviewEnabled=V1
MultiviewEnabled=V1
RequestMSI=SFALSE
EnableRestore=V1
