Where is the actual plugin? I haven't been following the thread and have no idea where to start.
if anyone has this fully working can you please upload your plugin somewhere and link to it for ppl like me that are having problems with all the code adding and such
jarod71 Wrote:what platform are you on? Are you on a XBOX?
just tried it and seems to work better. still getting script failed message but If I click link again, it produces list of shows and it works. will continue to test...
mynumbistongue Wrote:im on xbox and I was just surfing around trying to find 1 that worked and voila.
Also I am using this build of xbmc http://aero.exotica.org.uk/~jools/xbmc/x...ibrtmp.zip
how did you surf around lol? I am using the same build of xbmc as you. thanks for posting the link. the plugin works for the most part. still a little glitchy but I can watch the tv shows. can't test now, my 4 year old is watching spiderman on hulu lol. as soon as he is done, I will try movies etc...
gypherogha Wrote:I've got it working on my on my XBox using the fix located here.
http://forum.xbmc.org/showpost.php?p=539...tcount=153
You need to be using the XBMC version located here
http://malus.exotica.org.uk/~buzz/xbmc/
Built by exobuzz.
You'll also need the version of the Hulu Plugin located here
http://gitorious.org/xbmc-hulu
You can easily do this yourself if you have a little patience, but for those of you who don't feel like editing about 30 python files or getting patch to work, I'll be posting my lib folder later today as I'm at work right now for quick and easy drag and drop installation.
Heres the lib folder a bit earlier than expected (thanks VNC), just add it to your hulu/resources folder and agree to replacing all the files!
http://www.filefactory.com/file/b1d6g4h/n/lib_zip
Hope this makes it easier for people like myself who ran all around the internets trying to get Hulu on their XBMC machine.
I was reading this and saw the link to the hulu plugin here, well kreach also has a build on there where it says personal clones. I think his is the one to watch cuz it seems to be more functional than any others I've seen.
mynumbistongue Wrote:I was reading this and saw the link to the hulu plugin here, well kreach also has a build on there where it says personal clones. I think his is the one to watch cuz it seems to be more functional than any others I've seen.
thanks! kids are watching veggietales now with the plugin. workign great so far...
Glad I could help after all the trouble I had searching for a working one.
Has anyone got this working on a Windows build? If someone could post instructions, that would be fantastic. Hulu is the only thing that has me switching over to Boxee from my otherwise all-XBMC htpc.
nowonmai Wrote:This version has been working flawlessly for me. Many props to you bro.
it is working well for me too. still has a few issues when pulling in lists of shows, not sure if it is network timeouts though. will test and see.
