fedorafitz Wrote:I have compiled gnash from source and it is installed ok. I also installed the plugin using the SVN plugin, but when I try to view a video i get the following error. Been pulling my hair out for days over this. Any thoughts?
21:26:56 T:2628721552 M: 28012544 ERROR: dll_fstat64 emulated function failed
21:26:56 T:2628721552 M: 28012544 WARNING: dll_setvbuf - May not be implemented correctly
21:26:56 T:2628721552 M: 28012544 NOTICE: Traceback (most recent call last):
21:26:56 T:2628721552 M: 28012544 NOTICE: File "/opt/boxee/plugins/video/Hulu/default.py", line 60, in ?
21:26:56 T:2628721552 M: 28012544 NOTICE: modes ( )
21:26:56 T:2628721552 M: 28012544 NOTICE: File "/opt/boxee/plugins/video/Hulu/default.py", line 36, in modes
21:26:56 T:2628721552 M: 28012544 NOTICE: stream_media.Main()
21:26:56 T:2628721552 M: 28012544 NOTICE: File "/opt/boxee/plugins/video/Hulu/resources/lib/stream_hulu.py", line 14, in __init__
21:26:56 T:2628721552 M: 28012544 NOTICE: self.play()
21:26:56 T:2628721552 M: 28012544 NOTICE: File "/opt/boxee/plugins/video/Hulu/resources/lib/stream_hulu.py", line 31, in play
21:26:56 T:2628721552 M: 28012544 NOTICE: smilURL = "http://releasegeo.hulu.com/content.select?pid=" + hulu_decrypt(pid) + "&mbr=true&format=smil"
21:26:56 T:2628721552 M: 28012544 NOTICE: TypeError
21:26:56 T:2628721552 M: 28012544 NOTICE: :
21:26:56 T:2628721552 M: 28012544 NOTICE: cannot concatenate 'str' and 'NoneType' objects
21:26:56 T:2628721552 M: 28012544 ERROR: Scriptresult: Error
21:26:57 T:2628721552 M: 28086272 INFO: Python script stopped
I'm seeing pretty much the same thing when I try to click through to view. I'm running a local build of XBMC (r18214) on MacOS 10.5.6, with Hulu plugin r655.
21:48:46 T:2959986688 M:245587968 NOTICE: Traceback (most recent call last):
21:48:46 T:2959986688 M:245587968 NOTICE: File "/Users/jonathan/Library/Application Support/XBMC/plugins/video/Hulu/default.py", line 63, in ?
21:48:46 T:2959986688 M:245596160 NOTICE:
21:48:46 T:2959986688 M:245596160 NOTICE: modes ( )
21:48:46 T:2959986688 M:245587968 NOTICE: File "/Users/jonathan/Library/Application Support/XBMC/plugins/video/Hulu/default.py", line 36, in modes
21:48:46 T:2959986688 M:245592064 NOTICE:
21:48:46 T:2959986688 M:245592064 NOTICE: stream_media.Main()
21:48:46 T:2959986688 M:245583872 NOTICE: File "/Users/jonathan/Library/Application Support/XBMC/plugins/video/Hulu/resources/lib/stream_hulu.py", line 14, in __init__
21:48:46 T:2959986688 M:245592064 NOTICE: self.play()
21:48:46 T:2959986688 M:245583872 NOTICE: File "/Users/jonathan/Library/Application Support/XBMC/plugins/video/Hulu/resources/lib/stream_hulu.py", line 31, in play
21:48:46 T:2959986688 M:245592064 NOTICE: smilURL = "http://releasegeo.hulu.com/content.select?pid=" + hulu_decrypt(pid) + "&mbr=true&format=smil"
21:48:46 T:2959986688 M:245592064 NOTICE: TypeError
21:48:46 T:2959986688 M:245592064 NOTICE: :
21:48:46 T:2959986688 M:245592064 NOTICE: cannot concatenate 'str' and 'NoneType' objects
So something is amiss. (My default.py has one more elseif in it for those of you who noticed the line numbers weren't exactly the same; I'm working the subscriptions stuff, and that is the caller for it.)
