Nice patch... BUT now I can't just use the remote through the event server...
the_alien Wrote:Nice patch... BUT now I can't just use the remote through the event server...
Do you use the remote without using the web API?
Would it work for you if we'll show just the remote option if the web interface can't connect?
Hi. Had some problems with the httpapi not being reachable, so I just used the remote through the event server. Now I got everything to work, BUT web server and event server are 2 options to start, so it should be handled different. Maybe someone just uses the event server, so it should be available in the menu even without connection to the web server.
NetHunter Wrote:Do you use the remote without using the web API?
kindof nice idea, it's added on SVN now.
EDIT: New version available! v0.3
Wow, the new version is awesome!
Even time for 0.3.1 directly aswell
The new menu looks very nice. I was wondering if you could add a red-and-white colored remote screen to match the new menu icons?
Yep, looks great !!!!
But how can I change view in music (library), it's not in the menu now like in version 2.4.
Little bug: when use in remote the scrollball (which is still to sensitive), screen goes down a litlle bit.
edit : update already let's look.
Waffa Wrote:Yep, looks great !!!!
First one is disabled since it's abit buggy
second is weird
New update as download, just some fixes in nav in home.
EDIT: since I posted this 0.3.3 and 0.3.4 is updated. 0.3.3 is abit weird since I commited at the same time as I posted the build so it really is r99 + r101, so not really r100. Just wanted to share that so all home compilers know exactly which rev it was, so we honour GPL
EDIT: Fixed issue 4 in v0.3.5.1, please all update to it imediatly
Hi
I made a patch for your remote to pause playback when playing anything, show contact and pic in a notification and resume playback when you hang up. Plus show sms with contact name, pic and the first part of the sms when you receive one.
Could post the patch if you like.
TODOs:
- add config points
- privacy setting (do not show the sms or caller info, just a notification that a sms came in or a call is coming in)
the_alien Wrote:Hi
TODOs:
- add config points
Nice, please post the patch on the google code page and one of the members will take a look at it asap
ccMatrix Wrote:The new menu looks very nice. I was wondering if you could add a red-and-white colored remote screen to match the new menu icons?
I was thinking about that too, but I ended up keeping the retro style Xbox-colors
May be worth a settings trigger though
@topfs2: You cold add "TMobile G1" to your "Tried with" section, too, since I'm using and developing it on the G1
