weel, i've watched your db, it seems that when an imdb is present, thetvdbid is not take by xbmc, i can't use imdb id for now because xbmcstuff is indexed with thetvdbid...
ok, i'm working on a solution to take tvdbid in tvshow.nfo in tvshow folder if the id in db is imdb id, i'll tell you when it's done
updated, see first post, now search in tvshow.nfo too
still getting an error. here's the debug log:
http://pastebin.com/m112e4e83
it could be because my tv shows are on a NAS, and not local. it's not finding the tvshow.nfo file even though it's there and the path is correct.
ok, must be a unicode error, i tested it on local, i should post corected version tonight
updated, you shouldn't have problem with tvshow.nfo on smb share now
Awesome! Will give it a test tonight.
hum, strange!
xbox platform?
have you try it on other platform?
can u send me your smb://.../TV Shows/Bones/tvshow.nfo
i'll check this tonight
I just sent that out quick cause I didn't have a lot of time last night. Leaving for a hiking trip tonight after work, I *may find the time to send it out, no promises tho....
no problem, as soon as you want, your problem seem to be very strange.
No, I haven't tested it on my win xp or linux system yet. Will also do when I can.
UPDATED v1.2
see first post
now image in cache are replaced, no need to refresh library !
updated: fix some language issues with season image cache .
sometime (seen on vista), cache is not refresh (in fact it is but xbmc doesn't care...) just restart xbmc and image will show up !
Thanks a lot
