2009-12-20, 06:15
2009-12-20, 13:32
just post your xbmc.log, i'll see what happens.
when does it fail?
file location depends on your platform.
when does it fail?
2009-12-20, 17:15
2010-01-03, 12:51
I installed this vidoe plugin via the svn repo installer and when I went into the Video plugins folder and choose a tv series, it's immediately says script failed.
http://xbmc.pastebin.com/m3ad21959
2010-01-03, 17:53
ok little problem, just create a file named "temp.xml"
in XbmcStuff downloader\resources\data\
will correct that
will correct that
2010-01-07, 03:04
update: 07 jan 10
v1.5 add coloring , previews on different stage, detect bad thumb size, even for season thumbs! adding PIL lib.
2010-01-10, 23:56
Does this plugin work on AppleTV XBMC 9.11 with the Transparency skin ?
2010-01-11, 00:10
it should, yes.
2010-01-11, 09:00
ppic Wrote:just post your xbmc.log, i'll see what happens.
when does it fail?
http://pastebin.com/m40b3dd6e
It fails immediately after clicking on the title to run it.
2010-01-11, 13:22
00:55:32 T:2972363664 M:2300588032 NOTICE: Traceback (most recent call last):
00:55:32 T:2972363664 M:2300588032 NOTICE: File "/home/xbmc/.xbmc/plugins/video/XbmcStuff downloader/default.py", line 85, in ?
00:55:32 T:2972363664 M:2300588032 NOTICE: clearart_in_tv_folder=(False,True)[ int( xbmcplugin.getSetting("clearart folder") ) ]
00:55:32 T:2972363664 M:2300588032 NOTICE: ValueError: invalid literal for int(): none
00:55:32 T:2972363664 M:2300588032 NOTICE: File "/home/xbmc/.xbmc/plugins/video/XbmcStuff downloader/default.py", line 87, in ?
00:55:32 T:2972363664 M:2300588032 NOTICE: print "clearart_in_tv_folder= %s" % clearart_in_tv_folder
00:55:32 T:2972363664 M:2300588032 NOTICE: NameError
00:55:32 T:2972363664 M:2300588032 NOTICE: :
00:55:32 T:2972363664 M:2300588032 NOTICE: name 'clearart_in_tv_folder' is not defined
set your cleararts folder in plugin option.
2010-03-19, 13:03
Just set this Plugin up and it looks great!
Can get to all my TV shows and it brings up the clearart for them all etc...
But when trying to actually download the clearart it comes up saying 'Error Downloading'
XBMC log is here: http://pastebin.com/UPwSs2S0
Can anyone shed some light?
Thanks a million in advance!
2010-03-19, 13:30
it seems it doesn't find the path where to put cleararts:
Quote:IOError: [Errno 2] No such file or directory: 'smb://INNY/TV Series/Californication/clearart.png'
2010-03-19, 13:56
Right, so do i have to create a folder within my TV Series SMB called 'clearart'?
2010-03-19, 14:06
no, it should create a clearart.png in your tvshow folder.
can you try by manually create a file called "clearart.png" in your tvshow folder and try to download the clearart for this show?
2010-03-19, 14:32
Ok, Tried that and didnt work!
But i tried changing the location to skin/Transparency!/media/clearart/ and the file downloaded but doesnt show when playing a series (24)
Thanks again for your help!
