2009-11-04, 18:07
Hi everyone,
I've been searching for a while and haven't found any answers so I hope that you can help me. I'm hoping that the answer is a minor tweak that I've overlooked that someone can just point out.
I've been trying to add a source to the xbmc library with TV shows in it to no avail. Funnily enough, I've also added a source with my movies in it and that seems to be working fine (except that recently I noticed at least one of the movies is not showing up... on a side note, is there any way to ensure all my movies show up in the library?)
Here is the process I went through to try and add the TV show source:
Navigated to Watch TV Shows > Files (in the pop-up context menu) > Add Source
When I added the source I used the "set content" dialogue to choose IMDB as the default TV show scraper and told it to scan for new content.
The scan lasted maybe a minute (this is probably the equivalent of 5 seconds to most systems, I'm running xbmc on a mini-itx pc that has all the firepower that an Intel Atom can provide). I tried this method with a few different folders with varying amounts of failure:
If I added my drive with all my TV shows in it as a source (folder structure: TV Show Name / Season X / episode files) then I could see a listing of some (not all) of the shows on my drive but it claimed there were no episodes available to watch.
If I added either a tv show folder or a season folder as a source, then xbmc simply said I had no TV shows to watch.
However, If I navigated to TV Shows > Files (in the pop-up context menu) after adding any of these dirves or folders as sources then I would be able to browse through all the files and even play them.
Another quirk I found was that if, while browsing the files on the source, I manually added that file to the library, it showed up in my movies section (but without any descriptions or thumbs or fanart or anything like that).
Any suggestions on how I can get everything running smoothly?
