2009-12-16, 11:12
Hitcher Wrote:Cheers, I didn't look into this because I'm going to update the Files view at some time anyway.
all lines are scroll now, that makes giddiness. I think just current line scroll is good.
succo Wrote:i found a bug (under linux, at least), as when playing a movie/audio file the overlay to the home menu is all merged in one single line, as the [noparse][CR][/noparse] in the code would not be parsed... it depends on the : in the xml files, at line 47 of VideoOverlay.xml and at line 55 and 70 of MusicOverlay.xmlFixed.
it's enough to make the lines in MusicOverlay.xml like this
andCode:[noparse]<label>$LOCALIZE[31004][CR][b][color=NowPlayingTrack]$INFO[MusicPlayer.Title][/color][/b][CR][b]$INFO[MusicPlayer.Artist][/b][CR][color=NowPlayingAlbum]$INFO[MusicPlayer.Album][/color]</label>[/noparse]
and the line in VideoOverlay.xml likeCode:[noparse]<label>$LOCALIZE[31004][CR][b][color=NowPlayingTrack]$INFO[MusicPlayer.Title][/color][/b][CR][b]$INFO[MusicPlayer.Artist][/b][CR][color=NowPlayingAlbum]$INFO[MusicPlayer.Album][/color]</label>[/noparse]
and it's all goneCode:[noparse]<label>$LOCALIZE[31004][CR][b][color=NowPlayingTrack]$INFO[VideoPlayer.Title][/color][/b][CR][color=NowPlayingAlbum]$INFO[VideoPlayer.TVShowTitle][/color]</label>[/noparse]
btw, if we like the : in now playing it's enough to make string 31004 NOW PLAYING: in our strings.xml and that's all
taxigps Wrote:Don't remove font13 in font.xml. this is the default font xbmc used. xbmc may crash when font13 not define.Thanks, I didn't realise.
sinarquia Wrote:I gave the skin another try today, after I saw the messages regarding DialogNumeric.xml. Now the numeric panel appears, and I can enter the numbers, but cannot navigate to the Done button, or the arrows.To do.
Xbmc 9.11 beta2, Linux.
taxigps Wrote:all lines are scroll now, that makes giddiness. I think just current line scroll is good.Good catch.
aflo Wrote:
aflo Wrote:You're not using an old build of XBMC are you?
Amra Wrote:I'm not sure if this has been mentioned before but my AM/PM is switched. If you look at the screenshot in my post before this it says "6:41 PM" but the time was actually "6:41 AM". I tried another skin to make sure it was not an XBMC error but that skin was fine.Fixed.
Thanks again for all the hard work.
Hitcher Wrote:That's the 'Red Slate' theme.
Hitcher Wrote:You're not using an old build of XBMC are you?
Fixed.
Quote:Starting XBMC, Platform: GNU/Linux. Built on Dec 17 2009 (SVN:25756)
ppic Wrote:is it possible to disable the default icon that appears on xbmc notification if image parameter is passed?
the problem was the same in aeon, i know that temmi200 as modified his mod to handle it.
tried to figure out with dialogkaytoast.xml, but haven't find the way.
<control type="image" id="404">
<description>Icon</description>
<posx>322</posx>
<posy>10</posy>
<width>50</width>
<height>50</height>
<texture>dialogs/notification.png</texture>
<colordiffuse>ButtonFilterColor</colordiffuse>
</control>
