2009-12-19, 09:43
2009-12-19, 09:43
2009-12-21, 16:09
2009-12-21, 17:28
2009-12-21, 21:17
2009-12-21, 21:59
2009-12-22, 07:26
@aflo
ahh... that explains it. I checked out the to-do thread and didn't find it there so I was thinking it might have been a bug hehe. Thanks.
It's not that often that I use playlist anyways, so I'm sticking with this nice skin for the time being
2009-12-22, 12:00
2009-12-22, 13:16
Hitcher Wrote:A bigger image would help.
Also, what skin version and res are you using?
Hi Hitcher,
the last Version from Alaska, which work normal was b92599a.
All later Version have this problem.
My res ist 1280x800 and 1920x1080. Both the same problem.
xbmc ist 9.11 RC1
Thanks for Help
Edit:
Version b92599a
2009-12-22, 18:22
Is there a way to refresh Movie/TV Show information using Alaska? I usually have an option for "Refresh Movie Info" in the context menu, but noticed last night it's missing. Is it not implemented at this point?
2009-12-22, 19:10
ECEC Wrote:Is there a way to refresh Movie/TV Show information using Alaska? I usually have an option for "Refresh Movie Info" in the context menu, but noticed last night it's missing. Is it not implemented at this point?I've don't think I've ever seen it in the context menu but it's always been available from the Information screen (press Up or Down).
2009-12-22, 19:17
I don't know why I didn't think of that. :duh: Thanks for the info!
2009-12-28, 13:53
Hi Hitcher, Hi @all,
this bug is fixed with xbmc version from 24. Dec.
greets Nubert
greets Nubert
Nubert Wrote:Hi Hitcher,
xbmc ist 9.11 RC1
Thanks for Help
Edit:
Version b92599a
2009-12-28, 14:17
I thought you'd fixed it anyway judging from your last edit.
2009-12-29, 23:06
RomanPN Wrote:i have an issue (and i put it here because i don't wanna start a new thread) ... the problem is instad of *ALL SEASON i get only SEASON 1 twice, i tried it with different skins but the problem only appears in alaska (as always sorry for my english )
Screenshot:
thx for the help
I opened a TRAC ticket for this because it is happening with other skins too
http://trac.xbmc.org/ticket/8307
http://forum.xbmc.org/showpost.php?p=465...tcount=925
2009-12-29, 23:25
Screenshot:
thx for the help
Are you running a SVN build or a stable release?
