Any ideas on a release date to include the new frodo compatible notifications ?
code has been submitted to the development branch.. so it will get it first and some other bug fixes.. next binary build should have it.. which hopefully will go out before frodo goes public. and yes we are aware that the frodo beta1 comes out today..
excellent. looking forward to it
Hello,
Will it be possible in the feature to add 2 directories for 1 show? My first disk on NAS1 is full and i placed a new disk in my 2nd NAS.
I would like to have Sickbeard read the 2 directories. 1 for my archive and 1 for the newer episodes ( and downloads )
I know there is a workaround ( i saw more people with this "problem" )with symlinks but as far as i know there isn't a option to have 2 directories for 1 show?
Thanks in advance.
(2012-11-11, 20:50)Henkske Wrote: [ -> ]Hello,
Thanks in advance.
this is a problem you fix at your OS level not at sb. just manage your content however you want.. raid/symlinks/junction points/delete content/etc. you can always just create another parent dir and move some shows to that.
personally i take all the shows that have been cancelled/ended and move them off to a drive that only has x space. its not like any new episodes are going to appear there.. so you can just move the content, tell sb the new location for them (manage > mass update) and give that much space back to your active hd. also i go through and delete some old seasons from my wife's shows..
So I don't follow this thread too much, but my understanding is that the call to XBMC is broken until the next update of sickbeard because of Frodo. Is this correct?
(2012-11-14, 22:57)Mike8913 Wrote: [ -> ]So I don't follow this thread too much, but my understanding is that the call to XBMC is broken until the next update of sickbeard because of Frodo. Is this correct?
if you run sb from git and use the development branch, no you are fine. if you use sb binaries.. yes you would need to wait for the next build.
if you care to know whats upcoming for the next build (whats in development) you can check out:
https://github.com/midgetspy/Sick-Beard/wiki/ChangeLog
I just updated to the latest git and notifications are not working in frodo. Has the branch with this fixed not yet been merged ?
New versión still download zipped files?
(2012-11-15, 16:43)danz0l Wrote: [ -> ]I just updated to the latest git and notifications are not working in frodo. Has the branch with this fixed not yet been merged ?
you need to use the development branch. master = in sync with binaries
(2012-11-15, 18:06)achaw Wrote: [ -> ]New versión still download zipped files?
care to elaborate?
(2012-11-16, 03:10)thezoggy Wrote: [ -> ] (2012-11-15, 16:43)danz0l Wrote: [ -> ]I just updated to the latest git and notifications are not working in frodo. Has the branch with this fixed not yet been merged ?
AH i see. Will it get merged to master soon or is it going to be a long wait ? If so i'll chance my arm on the development branch. And how do i git clone the development branch or do i need to download and port over the zip ?
(2012-11-16, 15:32)danz0l Wrote: [ -> ]And how do i git clone the development branch or do i need to download and port over the zip ?
I'd like to know how to switch to dev as well
git checkout -b development
Yes i tried the same. Managed to get it working. Stop sickbeard and go into your git cloned sickbeard directory and type
Quote:git checkout -b development
That should get you onto sickbeard development branch. Then i could change to master or development via
Quote:git checkout development
or
Quote:git checkout master
to check which branch your on type
Quote:git branch
Remember to add entry in sickbeards config.ini
Quote:github_branch="development"
Restart sickbeard and it will tell you there is a new version available. (I only had 2 commits so was a little worried i'd got it wrong) Then just update
Now notification works in frodo
. Sickbeard main menu still says alpha master though ?
Updates from sickbeard are now incredibly fast. Is this now using the new JSON api ?
(2012-11-18, 13:00)danz0l Wrote: [ -> ]Yes i tried the same. Managed to get it working. Stop sickbeard and go into your git cloned sickbeard directory and type
or
Restart sickbeard and it will tell you there is a new version available. (I only had 2 commits so was a little worried i'd got it wrong) Then just update Now notification works in frodo
Thanks mate. I'd done most of that already but wasn't sure it had worked as it still says "Alpha Master" on the front page of SB (top left). Thought maybe that should say Development
I assume you can add "github_branch="development"" anywhere in the config? Or does it need to be in a specific place?
