¿Podría usted por favor código de todo el trabajo de código que subir o tal vez sólo el xml editado archivo para que el subforo Xperience no es tan desordenada? gracias!
I recently upgraded to the newest version of the SVN becuase I'm a Mac user and I wanted to take advantage of the hardware acceleration in the newest build. However now Xperience no longer shows up in my skins list. Now I've been told that the newest SVN build of XBMC has a new 'addons' framework that skins must adhere to which involves renaming a file or something to that affect. Does anyone know how I can get Xperience to work or what I have to do so I can use it with the newest XBMC build(s)?
So all i need to replace is the skin.xml with and addons.xml?
XBMCG33K Wrote:So all i need to replace is the skin.xml with and addons.xml?
That's how i did it
if i can do it then anybody can
Updated the svn and I will update the release page with a changelog.
See the post in the skin dev forum as to what you need do.
jmarshall Wrote:See the post in the skin dev forum as to what you need do.
Have already added the addon.xml as far as the other things I'll be adding them as soon as I can
yzack_1983 Wrote:IS BEAUTIFUL
IS AWESOME
IS FANTASTIC
AND THAT'S WHY IS MY DEFAULT SKIN
JUST CHECK IT OUT
http://www.megaupload.com/?d=XQA0XT1Y
Hi, I have the problem that when I go into the library of films, when switching from that view to "files", I get a panel at the bottom left of the screen,
with nothing inside, also occurs with any other type of view in the library of videos, as it is possible to solve this?
thanks, greetings
Hi for those of you who wants cdart on experience, it looks good for me i hope you'll like
as you can see the miniplayer now has a video window
as you can see the miniplayer now has the album cover and cdart
and here you can see the cdart
BACKGROUND
HOME PANEL
MINI MENU
LIBRARY
THE INSTRUCTIONS to put cdart:
put your cdart image in your music folder as this; music/artist/album/cdart.png
example; f:/music/akon/trouble/cdart.png
DOWNLOAD MOD HERE
http://www.megaupload.com/?d=OR8QNYW2
just extract and copy to your experience folder
does this also show in the visualisation screen?
takes balls to make proof you're listening to aqua public! ;P
spiff Wrote:takes balls to make proof you're listening to aqua public! ;P
that's Akon whoever he is. and it could be worse he could have used a cd of the smurfs
either way nice work doing this mod
