Full Version: MCE remote green button to start XBMC - Camelot final
Pages: 1 2 3 4 5 6 7 8 9
gunnerhead Wrote:Thanks so much, but unfortunately it didn't work. Maybe I should try uninstalling XBMC then reinstalling it and write back.
Thanks again though, you're the best Big Grin!
XBMCLauncher comes with an uninstaller that undoes its changes. It is listed in the Control Panel in Uninstall a Program.
If you're curious about what it does, the install script is in the SVN respository here: http://inchoatethoughts.com/xbmclauncher...script.nsi
I'm using XBMCLauncher with my Logitech DiNovo Mini and I love it!
I had this set up on both my Windows 7 XBMC boxes and then when I added the -d switch to delay the start up of of XBMC when booting this button stopped working.
Can anyone tell me how I can get both of them to work together?
