2010-05-21, 20:12
2010-09-07, 17:37
Anyone trying to post a new image when Dharma is released? I'm having an enormous amount of trouble trying to update everything.
2010-09-08, 03:36
Yeah. Having a ton of trouble with Dharma beta also. Keep dropping network shares even though I have IP. Also, lost iPhone XBMC remote connection to XBMC. It will work one day, not work the next. The box has IP and network, and reports internet is successful, however, do not get scrolling text on bottom of main screen, and it will not talk to anything on my network, and vice-versa.
Anyone else try the beta and have these issues?
2010-09-15, 17:01
Wow, I've been gone for a while, sorry, work's been killer.
I found myself searching for the damn link after a series of power outages nuked one of my boxes.
For anyone looking for screenshots, and it looks like there have been much much better walkthroughs since.
http://publicdump.s3.amazonaws.com/xbmcbuild.zip
Here's what I have from my last go round.
2010-09-15, 20:03
For anyone coming back to this thread, I think most of it is outdated at this point due to the number of fixes in the current version of Dharma as well as NVidia's drivers. There's a link to a more current setup walk-through using Dharma in my signature for anyone who is interested.
2012-06-01, 03:13
So I just bought one of these a few days ago, and am struggling a bit to eliminate the tearing... specifically at the top of the screen.
Below is my xorg. I am running Eden.
I am sort of at a loss as to what I can do additionally to solve this problem. The videos I am using to test are 720p.
Section "Monitor"
Identifier "Monitor0"
HorizSync 31 - 82
VertRefresh 57 - 63
Option "ExactModeTimingsDVI" "TRUE"
# Modeline "1920x1080" 148.50 1920 2008 2052 2200 1080 1084 1089 1125
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
Option "NoLogo" "true"
Option "DynamicTwinView" "false"
# Option "NoFlip" "false"
Option "FlatPanelProperties" "Scaling = Native"
Option "ModeValidation" "NoVesaModes, NoXServerModes"
Option "UseDisplayDevice" "DFP-1"
Option "ModeDebug" "true"
Option "HWCursor" "false"
Option "ModeValidation" "NoEdidModes"
EndSection
Section "Screen"
Identifier "screen"
Device "nvidia"
Monitor "Monitor0"
DefaultDepth 24
Option "NoLogo" "True"
Option "TripleBuffer" "false"
SubSection "Display"
Modes "1920x1080_60"
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Disable"
EndSection
2012-06-01, 08:07
(2012-06-01, 03:13)pyite Wrote: [ -> ]So I just bought one of these a few days ago, and am struggling a bit to eliminate the tearing... specifically at the top of the screen.
Don't know how you found this very old thread, but anyway, see:
Howto achieve judder free perfectly synced playback at 23.97/59.94 Hz
Also I suggest you see:
xbmc cannot set resolution/refresh properly with nvidia cards in 12.04
and note the comments underneath that report. To use the Nathan Rennie-Waldock PPA instead of the default Ubuntu repositories, do this:
1. Remove the xbmc and xbmc-bin packages using Synaptic or your favorite package manager (you can install Synaptic using apt-get install synaptic if you don't already have a package manager installed).
2. From a terminal prompt do:
sudo add-apt-repository ppa:nathan-renniewaldock/xbmc-stable
sudo apt-get update
3. Go back into Synaptic or your package manager of choice and (re)install xbmc and xbmc-bin.
Note your existing XBMC settings should not be affected as long as you don't delete the .xbmc directory in your user directory (so, don't do that unless you want to start over completely from scratch).
For more information on problems with the version of XBMC offered in Ubuntu's repository see Linux HTML Entities being used such as &
2012-06-01, 14:21
I searched... alot haha
Thanks for your suggestions, I will check them out.
