Place in your installed XBMC/media folder.
Thanks to Noodie for this and also the new style Settings button.
XBMC/media folder? do you mean the Alaska/Media folder? I don't have a "media" folder in my xbmc folder, only the following:
plugins
screensavers
scrpits
skin
sounds
system
temp
userdata
visualisations
so i just tried putting it in my alaska/media folder, and got nothing...im confused? I also tried making a media folder in the XBMC folder and putting splashh.png in there as well...no dice..
Custom splash screens are not supported in the latest XBMC 9.11 release. You'll need a more recent nightly build in order to use it.
vdrfan Wrote:Custom splash screens are not supported in the latest XBMC 9.11 release. You'll need a more recent nightly build in order to use it.
Which everyone should be doing anyway if they followed the instructions in the release thread.
Hitcher Wrote:Which everyone should be doing anyway if they followed the instructions in the release thread.
Is there an easy walkthrough for the newbies on how to install the nightly build? :o
Download and run the executable from the link.
Hitcher Wrote:Download and run the executable from the link.
The github link? I thought it was a .deb file?
