[Bug?]
Not sure about this, but I think the new "Please insert the following disc:" dialog for offline movies is supposed to have a cancel option. Right now there's only an "Eject/Load" option and the only way to cancel is to press 'esc'
[Request - Important]
A toggle similar to the "Watched [Hidden/Visible]" but for offline movies.
[Request]
It would be great if the Info List for Music Videos listed both Artist and Track Name
[Request]
Would it be possible to have TV theme.mp3's fade out instead of ending abruptly when navigation away?
[Bug?]
1) Navigate to Music Root / Songs
2) Press Shift+<Letter>
Expected Result: Jump to the first song starting with that letter
Result: Jump to the first artist starting with that letter
Is there a way to change the volume indicator in the videoOSD to be similar to the one that is activated while not playing a video?
Hitcher would you have any idea why my Video folder no longer opens (Opens to a Black Screen). I have one of the nightly builds of XBMC (April 11) and also your repo version installed which is up to date. If I change to Jezz's stock skin it works fine but for some reason yours won't. No doubt I am being stupid as I should know better but am I missing something obvious.
Seems like forever since I was involved in any skinning .. :-(
Thanks in advance.
D
Hi all just a quick question
Can u use this skin on an apple tv with xbmc installed on it
Cheers
some of the video addons dont work, i get a these messages for the iplayer addon.
http://pastebin.com/H2KQZaLB
im using the current build and version
I'm pretty sure this has nothing to do with the skin; try it using another.
found another missing media flag:
pcm_s24le according to the db.
Switch to Confluence and let me know what shows.
Hitcher Wrote:Switch to Confluence and let me know what shows.
hmm, looks like it's missing in confluence as well. i could have sworn i'd seen a pcm flag before. this is a 24bit lpcm track. maybe there is one for a 16bit lpcm track (pcm_s16le) i'm thinking of? i don't have any files with this type of audio track right now.
my build is from apr 4 and the latest revision doesn't seem to want to compile for me so i'm not sure if confluence has been updated between then and now.
edit: just got it to compile and confluence still shows a blank spot where the flag should be.
Hi all
is there a way to display single season poster art like the Pacific as i dont want it to jump stright into thumbs i want to see the season 1 poster first is there a way of doing this
thanks
any joy if this skin will work with apple tv ?
cheers
furii Wrote:hmm, looks like it's missing in confluence as well. i could have sworn i'd seen a pcm flag before. this is a 24bit lpcm track. maybe there is one for a 16bit lpcm track (pcm_s16le) i'm thinking of? i don't have any files with this type of audio track right now.
Confluence doesn't have any pcm flags -
https://github.com/xbmc/xbmc/tree/master...ging/audio
For me to add it I'd need to know what they're meant to look like.
meridius Wrote:Hi all
thanks
cheers
That's an XBMC setting -
Video Settings > Library > Flatten TV Shows > Never.
Hitcher not sure if you saw my previous post but when using the latest version of your skin and a nightly build of XBMC I encounter a Black screen when accessing the Videos directory from home. I have noticed that the myvideo.xml has been removed from the skin and also a reference to it in your change log. This file still remains in Confluence and the Videos directory works as normal when testing using it.
Is the Videos Icon on home now redundant in Alaska Revisited or has a new structure been implemented to view non Library video items.
Any advise on this would be greatly appreciated as I just can't make sense of where the issue lies.
Thanks in advance
D
Sorry, missed it before.
Maybe your nightly build isn't up-to-date enough because that will now take you to the Files node of the Video Library.
To test this use Confluence and select Videos from the main menu and you should see a Files entry.
MyVideo.xml is now redundant.
Hitcher Wrote:Sorry, missed it before.
Thanks for the reply Hitcher I'll download another build to test but I'm sure the last one I used was 4th April 11.
