thesuffering Wrote:noticed an issue recently that i believe is due to alaska. I have PsuedoTV as a custom home item. I can launch into it and exit fine, however when it exits it gets stuck on the icon and i can move. Also the label "PsudeoTV" is gone and it says "Fair" (basically like if you press down on the weather icon). i can press any direction, back, ok, esc, x, stop, everything but it stays stuck. Only way i could get it working again was by force closing xbmc. It has happened every time i have used this script and custom home item
still having this problem
any ideas?
Hello every1
I have issues with logo/banner script. I see all my tv shows in my tv show section (banner view). The banner of my tv shoes are empty so i go to settings and i hit logo/banner/poster script to run . Its runs well but i get messege 0banners 0logos 0poster download
Any1 with the same problems?
Cashtro Wrote:Hello every1
If you are using latest nightlies and your tv shows are on Samba share then you are out of luck. Logo downloader script isn't present in pre-Eden addon repository because afaik it's not compatible with current standalone/system-level Python used in nightly XBMC. This standalone Python doesn't anymore support access to XBMC's VFS so it can't access your Samba shares directly.
P.S. Half of the statement above is my deduction from some posts around addon development forums so it can be plain wrong :p
bambi73 Wrote:P.S. Half of the statement above is my deduction from some posts around addon development forums so it can be plain wrong :p
It is the scripts just have to be coded in a different way
Yeah, i know that, i saw code snippet from Amet.
Looks like i wrote my response in bad way so it can be understood wrongly
Anyway it doesn't change anything on current state that it wasn't changed for pre-Eden nightlies so it doesn't work now.
has hitcher abandoned this thread? i havent seen him post here in a while, but he has posted quite regularly in the skin development forum
bambi73 Wrote:Yeah, i know that, i saw code snippet from Amet.
2bad i have last Nightlybuild .. than i have to wait
Hello,
I would like to know if it is possible to have submenus wih horizontal and verital home menu.
In this way I would like to access to sources. I often watch movies or tv show before scrap but for now I cannot do this with Alaska.
Thank you for your help
You can add them as main items.
I know I can add main items but in the custom item menu in alaska options, I can only add script or favorites, etc but not sources.
And I don"t know how to access to sources. If I choose "files" I do not have files, I have genre, year, director, etc.
In the alaska revisited mod, Files give me acces to sources
I have multiples sources and I would to access to.
Another problem, I can't have multple backdrops in the default home menu. But in alaska revisited mod multiples backdrops is ok.
I don't want to use alaska revisited mod because I love the lovefilm style in alaska revisited
wolfodeiwolfy Wrote:I know I can add main items but in the custom item menu in alaska options, I can only add script or favorites, etc but not sources.
I did somes modifications:
In dialogbuttonmenu.xml, "filemanager" label become "sources" and <onclick>ActivateWindow(filemanager)</onclick> become <onclick>ActivateWindow(Videofiles)</onclick>
I copy and paste Myvideo.xml from alaska revisited mod in appdata...\720p
It works very well and I don't have to enable "videos" on home menu
@Hitcher: I hope "sources" be added to the "s" menu in a future release (I will not have copy and paste xml each time !!!)
w2w
I recently formatted my Windows and downloaded the last nightly build, but I get a message that says the Alaska skin is broken. Please help!
fr500 Wrote:http://forum.xbmc.org/showpost.php?p=626137&postcount=1
I'm sorry for not explaining correctly. I had no problems with the installation before (I know exactly how it's done).
I don't have the opportunity to do as you say, because I have not installed Alaska on my computer. Reason:
Try manually installing it in the Addon folder.
